Gazebo Sensors
Manager Class Reference
#include <Manager.hh>
 Manager ()
 constructor More...
virtual ~Manager ()
 destructor More...
void AddPluginPaths (const std::string &_path)
 Adds colon delimited paths sensor plugins may be. More...
SensorId AddSensor (std::unique_ptr< Sensor > _sensor)
 Add a sensor for this manager to manage. More...
SensorId CreateSensor (const sdf::Sensor &_sdf)
 Create a sensor from SDF without a known sensor type. More...
SensorId CreateSensor (sdf::ElementPtr _sdf)
template<typename SensorType , typename SdfType >
SensorType * CreateSensor (SdfType _sdf)
 Create a sensor from an SDF ovject with a known sensor type. More...
bool Init ()
 Initialize the sensor library without rendering or physics. More...
bool Remove (const SensorId _id)
 Remove a sensor by ID. More...
void RunOnce (const std::chrono::steady_clock::duration &_time, bool _force=false)
 Run the sensor generation one step. More...
Sensor * Sensor (SensorId _id)
 Get an instance of a loaded sensor by sensor id. More...
This class is responsible for loading and running sensors, and providing sensors with common environments to generat data from.
The primary interface through which to load a sensor is LoadSensor(). This takes an sdf element pointer that should be configured with everything the sensor will need. Custom sensors configuration must be in the <plugin> tag of the sdf::Element. The manager will dynamically load the sensor library and update it.
Remarks
This class is not thread safe.
◆ Manager()
Manager ( )
constructor
◆ ~Manager()
virtual ~Manager ( )
destructor
◆ AddPluginPaths()
void AddPluginPaths ( const std::string &  _path)
◆ AddSensor()
SensorId AddSensor ( std::unique_ptr< Sensor >  _sensor)
Sensor()
[in]_sensorPointer to the sensor
A sensor id that refers to the created sensor. NO_SENSOR is returned on error.
◆ CreateSensor() [1/3]
SensorId CreateSensor ( const sdf::Sensor &  _sdf)
This creates sensors by looking at the given sdf element. Sensors created with this API offer an gz-transport interface. If you need a direct C++ interface to the data, you must get the sensor pointer and cast to the correct type.
A <sensor> tag may have multiple <plugin> tags. A SensorId will be returned for each plugin that is described in SDF. If there are no <plugin> tags then one of the plugins shipped with this library will be loaded. For example, a <sensor> tag with <camera> but no <plugin> will load a CameraSensor from gz-sensors-camera.
Sensor()
[in]_sdfSDF sensor DOM object
A sensor id that refers to the created sensor. NO_SENSOR is returned on erro.
Deprecated:
Sensor registration is deprecated, so it's necessary to provide the specific sensor type to create it. Use the templated CreateSensor function.
◆ CreateSensor() [2/3]
SensorId CreateSensor ( sdf::ElementPtr  _sdf)
Sensor()
[in]_sdfpointer to the sdf element
Deprecated:
◆ CreateSensor() [3/3]
SensorType* CreateSensor ( SdfType  _sdf)
inline
Sensor()
[in]_sdfAn SDF element or DOM object.
Template Parameters
SensorTypeSensor type
SdfTypeIt may be an sdf::ElementPtr containing a sensor or an sdf::Sensor.
A pointer to the created sensor. Null returned on error. The Manager keeps ownership of the pointer's lifetime.
References Manager::AddSensor(), SensorFactory::CreateSensor(), std::endl(), std::move(), and ignition::sensors::NO_SENSOR.
bool Init ( )
True if successfully initialized, false if not
◆ Remove()
bool Remove ( const SensorId  _id)
[in]_sensorIdID of the sensor to remove
True if the sensor exists and removed.
◆ RunOnce()
void RunOnce ( const std::chrono::steady_clock::duration &  _time,
bool  _force = false
_timeThe current simulated time
_forceIf true, all sensors are forced to update. Otherwise a sensor will update based on it's Hz rate.
◆ Sensor()
Sensor* Sensor ( SensorId  _id)
[in]_idIdenitifier of the sensor.
Pointer to the sensor, nullptr on error.
