Gazebo Sensors
SensorFactory Class Reference
#include <SensorFactory.hh>
 SensorFactory ()
 ~SensorFactory ()
void AddPluginPaths (const std::string &_path)
 Add additional path to search for sensor plugins. More...
template<typename SensorType >
std::unique_ptr< SensorType > CreateSensor (const sdf::Sensor &_sdf)
 Create a sensor from a SDF DOM object with a known sensor type. More...
std::unique_ptr< Sensor > CreateSensor (const sdf::Sensor &_sdf)
 Create a sensor from an SDF Sensor DOM object without a known sensor type. More...
std::unique_ptr< SensorType > CreateSensor (sdf::ElementPtr _sdf)
 Create a sensor from an SDF element with a known sensor type. More...
std::unique_ptr< Sensor > CreateSensor (sdf::ElementPtr _sdf)
 Create a sensor from SDF without a known sensor type. More...
◆ SensorFactory()
◆ ~SensorFactory()
◆ AddPluginPaths()
void AddPluginPaths ( const std::string &  _path)
[in]_pathSearch path
Deprecated:
Sensor plugins aren't supported anymore.
◆ CreateSensor() [1/4]
std::unique_ptr<SensorType> CreateSensor ( const sdf::Sensor &  _sdf)
inline
This creates sensors by looking at the given SDF DOM object. Sensors created with this API offer an gz-transport interface. If you need a direct C++ interface to the data, you must get the sensor pointer and cast to the correct type.
Sensor()
[in]_sdfSDF Sensor DOM object.
Template Parameters
SensorTypeSensor type
A pointer to the created sensor. Null returned on error.
References std::endl().
◆ CreateSensor() [2/4]
std::unique_ptr<Sensor> CreateSensor ( const sdf::Sensor &  _sdf)
This creates sensors by looking at the given SDF Sensor DOM object. Sensors created with this API offer an ignition-transport interface. If you need a direct C++ interface to the data, you must get the sensor pointer and cast to the correct type.
Sensor()
A sensor id that refers to the created sensor. Null is is returned on error.
Deprecated:
Sensor registration is deprecated, so it's necessary to provide the specific sensor type to create it. Use the templated CreateSensor function.
◆ CreateSensor() [3/4]
std::unique_ptr<SensorType> CreateSensor ( sdf::ElementPtr  _sdf)
inline
Sensor()
[in]_sdfpointer to the sdf element
Template Parameters
◆ CreateSensor() [4/4]
std::unique_ptr<Sensor> CreateSensor ( sdf::ElementPtr  _sdf)
This creates sensors by looking at the given sdf element. Sensors created with this API offer an gz-transport interface. If you need a direct C++ interface to the data, you must get the sensor pointer and cast to the correct type.
Sensor()
Null, as the function is deprecated.
Deprecated:
