Gazebo Sensors
gz/sensors/CameraSensor.hh
2  * Copyright (C) 2017 Open Source Robotics Foundation
16 */
17 #ifndef GZ_SENSORS_CAMERASENSOR_HH_
18 #define GZ_SENSORS_CAMERASENSOR_HH_
20 #include <cstdint>
21 #include <memory>
22 #include <string>
23
24 #include <sdf/sdf.hh>
25
26 #include <gz/common/SuppressWarning.hh>
27
28 #ifdef _WIN32
29 #pragma warning(push)
30 #pragma warning(disable: 4005)
31 #pragma warning(disable: 4251)
32 #endif
33 #include <ignition/msgs.hh>
34 #ifdef _WIN32
35 #pragma warning(pop)
36 #endif
37
38 // TODO(louise) Remove these pragmas once ign-rendering is disabling the
39 // warnings
40 #ifdef _WIN32
41 #pragma warning(push)
42 #pragma warning(disable: 4251)
43 #endif
44 #include <gz/rendering/Camera.hh>
45 #ifdef _WIN32
46 #pragma warning(pop)
47 #endif
48
49 #include "gz/sensors/camera/Export.hh"
50 #include "gz/sensors/config.hh"
51 #include "gz/sensors/Export.hh"
53
54 namespace ignition
55 {
56  namespace sensors
57  {
58  // Inline bracket to help doxygen filtering.
59  inline namespace IGNITION_SENSORS_VERSION_NAMESPACE {
60  //
62  class CameraSensorPrivate;
63
71  class IGNITION_SENSORS_CAMERA_VISIBLE CameraSensor : public RenderingSensor
72  {
74  public: CameraSensor();
75
77  public: virtual ~CameraSensor();
78
82  public: virtual bool Load(const sdf::Sensor &_sdf) override;
83
87  public: virtual bool Load(sdf::ElementPtr _sdf) override;
88
91  public: virtual bool Init() override;
92
96  public: virtual bool Update(
97  const std::chrono::steady_clock::duration &_now) override;
98
107  public: gz::common::ConnectionPtr ConnectImageCallback(
109  void(const gz::msgs::Image &)> _callback);
110
113  public: virtual void SetScene(
114  gz::rendering::ScenePtr _scene) override;
115
118  public: virtual unsigned int ImageWidth() const;
119
122  public: virtual unsigned int ImageHeight() const;
123
126  public: rendering::CameraPtr RenderingCamera() const;
127
130  public: std::string InfoTopic() const;
131
135  public: void SetBaseline(double _baseline);
136
139  public: double Baseline() const;
140
144  public: bool HasConnections() const;
145
149  public: bool HasImageConnections() const;
150
154  public: bool HasInfoConnections() const;
155
158  public: const std::string &OpticalFrameId() const;
159
162  protected: bool AdvertiseInfo();
163
169  protected: bool AdvertiseInfo(const std::string &_topic);
170
174  protected: void PopulateInfo(const sdf::Camera *_cameraSdf);
175
178  protected: void PublishInfo(
179  const std::chrono::steady_clock::duration &_now);
180
183  private: bool CreateCamera();
184
188  private: void OnSceneChange(gz::rendering::ScenePtr /*_scene*/);
189
190  IGN_COMMON_WARN_IGNORE__DLL_INTERFACE_MISSING
193  private: std::unique_ptr<CameraSensorPrivate> dataPtr;
194  IGN_COMMON_WARN_RESUME__DLL_INTERFACE_MISSING
195  };
196  }
197  }
198 }
199
200 #endif
Camera Sensor Class.
Definition: gz/sensors/CameraSensor.hh:72
virtual void SetScene(gz::rendering::ScenePtr _scene) override
Set the rendering scene.
Check if there are any info subscribers.
void PublishInfo(const std::chrono::steady_clock::duration &_now)
Publish camera info message.
const std::string & OpticalFrameId() const
Get the camera optical frame.
Get image height.
Topic where camera info is published.
Get image width.
Get baseline for stereo cameras.
Populate camera info message.
destructor
Advertise camera info topic. This version takes a string that allows one to override the camera_info ...
Get pointer to rendering camera object.
Check if there are any image subscribers.
gz::common::ConnectionPtr ConnectImageCallback(std::function< void(const gz::msgs::Image &)> _callback)
Set a callback to be called when image frame data is generated.
virtual bool Update(const std::chrono::steady_clock::duration &_now) override
Set baseline for stereo cameras. This is used to populate the projection matrix in the camera info me...
a rendering sensor class
Definition: gz/sensors/RenderingSensor.hh:54
