Gazebo Sensors
BoundingBoxCameraSensor Class Reference
BoundingBox camera sensor class. More...
#include <BoundingBoxCameraSensor.hh>
 BoundingBoxCameraSensor ()
 constructor More...
virtual ~BoundingBoxCameraSensor ()
 destructor More...
virtual rendering::BoundingBoxCameraPtr BoundingBoxCamera () const
 Get the rendering BoundingBox camera. More...
bool HasConnections () const
 Get image height. More...
 Get image width. More...
virtual bool Init () override
void OnNewBoundingBoxes (const std::vector< rendering::BoundingBox > &_boxes)
 Callback on new bounding boxes from bounding boxes camera. More...
virtual void SetScene (ignition::rendering::ScenePtr _scene) override
 CameraSensor ()
 constructor More...
virtual ~CameraSensor ()
 destructor More...
double Baseline () const
bool HasImageConnections () const
 Check if there are any image subscribers. More...
bool HasInfoConnections () const
 Check if there are any info subscribers. More...
 Get the camera optical frame. More...
virtual ~RenderingSensor ()
 destructor More...
void Render ()
 destructor More...
bool EnableMetrics () const
std::string FrameId () const
 FrameId. More...
SensorId Id () const
 Get the sensor's ID. More...
bool IsActive () const
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
void SetActive (bool _active)
std::string Topic () const
 Update the sensor. More...
double UpdateRate () const
bool AdvertiseInfo ()
 RenderingSensor ()
 constructor More...
 Sensor ()
 constructor More...
This class creates a BoundingBox image from an ignition rendering scene. The scene must be created in advance and given to Manager::Init(). It offers both an ignition-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ BoundingBoxCameraSensor()
constructor
◆ ~BoundingBoxCameraSensor()
virtual ~BoundingBoxCameraSensor ( )
destructor
◆ BoundingBoxCamera()
virtual rendering::BoundingBoxCameraPtr BoundingBoxCamera ( ) const
BoundingBox camera pointer
◆ HasConnections()
bool HasConnections ( ) const
Todo:
◆ ImageHeight()
Get image height.
height of the image
◆ ImageWidth()
Get image width.
width of the image
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ OnNewBoundingBoxes()
void OnNewBoundingBoxes ( const std::vector< rendering::BoundingBox > &  _boxes)
[in]_boxesDetected bounding boxes from the camera
◆ SetScene()
virtual void SetScene ( ignition::rendering::ScenePtr  _scene)
[in]_nowThe current time
true if the update was successful
