Gazebo Sensors
AirPressureSensor Class Reference
#include <AirPressureSensor.hh>
 AirPressureSensor ()
 constructor
virtual ~AirPressureSensor ()
 destructor
virtual bool Init () override
double ReferenceAltitude () const
 Get the vertical reference altitude.
void SetReferenceAltitude (double _reference)
 Set the reference altitude.
 Update the sensor.
 destructor
bool EnableMetrics () const
std::string FrameId () const
 FrameId.
SensorId Id () const
 Get the sensor's ID.
bool IsActive () const
bool IsTriggered () const
std::string Name () const
 Get name.
std::string Parent () const
 Get the current pose.
sdf::ElementPtr SDF () const
void SetActive (bool _active)
 Set Frame ID of the sensor.
 Set the parent of the sensor.
std::string Topic () const
 Update the sensor.
double UpdateRate () const
 Sensor ()
 constructor
A sensor that reports air pressure readings.
◆ AirPressureSensor()
constructor
◆ ~AirPressureSensor()
virtual ~AirPressureSensor ( )
destructor
◆ HasConnections()
Reimplemented from Sensor.
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ ReferenceAltitude()
double ReferenceAltitude ( ) const
Verical reference position in meters
◆ SetReferenceAltitude()
void SetReferenceAltitude ( double  _reference)
[in]_referenceVerical reference position in meters
◆ Update() [1/3]
[in]_nowThe current time
Implements Sensor.
◆ Update() [2/3]
SetUpdateRate()
Implements Sensor.
◆ Update() [3/3]
const bool  _force
Update the sensor.
Remarks
