Gazebo Sensors
a base sensor class More...
#include <Sensor.hh>
 destructor
bool EnableMetrics () const
std::string FrameId () const
 FrameId.
virtual bool HasConnections () const
SensorId Id () const
 Get the sensor's ID.
virtual bool Init ()
 Initialize values in the sensor This will set the next update time to zero. This is particularly useful if simulation time has jumped backward, for example during a seek backward in a log file.
bool IsActive () const
bool IsTriggered () const
virtual bool Load (sdf::ElementPtr _sdf)
std::string Name () const
 Get name.
std::string Parent () const
 Get the current pose.
sdf::ElementPtr SDF () const
void SetActive (bool _active)
 Set Frame ID of the sensor.
 Set the parent of the sensor.
std::string Topic () const
 Update the sensor.
double UpdateRate () const
 Sensor ()
 constructor
a base sensor class
This class is a base for all sensor classes. It parses some common SDF elements in the <sensor> tag and is responsible for making sure sensors update at the right time.
◆ Sensor()
Sensor ( )
constructor
◆ ~Sensor()
virtual ~Sensor ( )
destructor
◆ AddSequence()
void AddSequence ( gz::msgs::Header *  _msg,
const std::string &  _seqKey = "default"
This function will add the following key-value pair to the data field in the provided gz::msgs::Header msg.
  • key: "seq"
  • value: sequence_number
If the "seq" key already exists, then the value will be set without adding another key-value pair.
The sequence_number starts at zero, when a sensor is created, and is incremented by one each time this function is called.
[in,out]_msgThe header which will receive the sequence.
[in]_seqKeyName of the sequence to use.
◆ EnableMetrics()
bool EnableMetrics ( ) const
True if performance metrics are enabled, false otherwise.
◆ FrameId()
std::string FrameId ( ) const
FrameId.
FrameId of sensor.
◆ HasConnections()
◆ HasPendingTrigger()
bool HasPendingTrigger ( ) const
True if the sensor is in trigger mode and has a pending trigger.
◆ Id()
SensorId Id ( ) const
The sensor's ID.
virtual bool Init ( )
Reimplemented in AirPressureSensor, AirSpeedSensor, AltimeterSensor, BoundingBoxCameraSensor, CameraSensor, DepthCameraSensor, ForceTorqueSensor, GpuLidarSensor, ImuSensor, Lidar, LogicalCameraSensor, MagnetometerSensor, NavSatSensor, RgbdCameraSensor, SegmentationCameraSensor, ThermalCameraSensor, and WideAngleCameraSensor.
◆ IsActive()
bool IsActive ( ) const
True if the sensor is active, false otherwise.
SetActive
◆ IsTriggered()
bool IsTriggered ( ) const
True if the sensor is in trigger mode, false otherwise
◆ Load() [1/2]
[in]_sdfSDF <sensor> or <plugin> inside of <sensor>
Reimplemented in AirPressureSensor, AirSpeedSensor, AltimeterSensor, BoundingBoxCameraSensor, CameraSensor, DepthCameraSensor, DopplerVelocityLog, ForceTorqueSensor, GpuLidarSensor, ImuSensor, Lidar, MagnetometerSensor, NavSatSensor, RgbdCameraSensor, SegmentationCameraSensor, ThermalCameraSensor, and WideAngleCameraSensor.
◆ Load() [2/2]
Reimplemented in AirPressureSensor, AirSpeedSensor, AltimeterSensor, BoundingBoxCameraSensor, CameraSensor, DepthCameraSensor, DopplerVelocityLog, ForceTorqueSensor, GpuLidarSensor, ImuSensor, Lidar, LogicalCameraSensor, MagnetometerSensor, NavSatSensor, RgbdCameraSensor, SegmentationCameraSensor, ThermalCameraSensor, and WideAngleCameraSensor.
◆ Name()
std::string Name ( ) const
Get name.
Name of sensor.
◆ NextDataUpdateTime()
std::chrono::steady_clock::duration NextDataUpdateTime ( ) const
◆ Parent()
std::string Parent ( ) const
Parent link of sensor.
◆ Pose()
gz::math::Pose3d Pose ( ) const
Current pose of the sensor.
◆ PublishMetrics()
void PublishMetrics ( const std::chrono::duration< double > &  _now)
[in]_nowCurrent time.
◆ SDF()
sdf::ElementPtr SDF ( ) const
Pointer to an SDF element that contains initialization information for this sensor.
◆ SetActive()
void SetActive ( bool  _active)
[in]_activeTrue to set the sensor to be active, false to disable the sensor.
IsActive
◆ SetEnableMetrics()
void SetEnableMetrics ( bool  _enableMetrics)
[in]_enableMetricsTrue to enable.
◆ SetFrameId()
void SetFrameId ( const std::string &  _frameId)
[in]_frameIdFrame ID of the sensor
◆ SetNextDataUpdateTime()
void SetNextDataUpdateTime ( const std::chrono::steady_clock::duration &  _time)
[in]_timeThe next update time
◆ SetParent()
virtual void SetParent ( const std::string &  _parent)
Reimplemented in Lidar.
◆ SetPose()
void SetPose ( const gz::math::Pose3d &  _pose)
◆ SetTopic()
bool SetTopic ( const std::string &  _topic)
[in]_topicTopic sensor publishes data to.
True if a valid topic was set.
◆ SetTriggered()
bool SetTriggered ( bool  _triggered,
const std::string &  _triggerTopic = ""
  • the sensor will only update if a new message has been published to the passed _triggerTopic since the last update,
  • until the next message is published on _triggerTopic, all Update calls will return false, and
  • if the sensor has a pending trigger, the next Update call will ignore the sensor's update rate and try generate data immediately.
    [in]_triggeredSets triggered mode if true and disables it if false.
    [in]_triggerTopicThe topic on which the sensor will listen for trigger messages in triggered mode. If _triggered is true, this value should not be empty. If _triggered is false, this value is ignored.
    True if the operation succeeded.
◆ SetUpdateRate()
void SetUpdateRate ( const double  _hz)
Negative rates become zero.
[in]_hzUpdate rate of sensor in Hertz.
◆ Topic()
std::string Topic ( ) const
◆ Update() [1/2]
[in]_nowThe current time
SetUpdateRate()
Implemented in AirPressureSensor, AirSpeedSensor, AltimeterSensor, BoundingBoxCameraSensor, CameraSensor, DepthCameraSensor, DopplerVelocityLog, ForceTorqueSensor, GpuLidarSensor, ImuSensor, Lidar, LogicalCameraSensor, MagnetometerSensor, NavSatSensor, RgbdCameraSensor, SegmentationCameraSensor, ThermalCameraSensor, WideAngleCameraSensor, AirPressureSensor, AirSpeedSensor, AltimeterSensor, CameraSensor, ForceTorqueSensor, ImuSensor, LogicalCameraSensor, and MagnetometerSensor.
◆ Update() [2/2]
const bool  _force
Update the sensor.
Remarks
◆ UpdateRate()
double UpdateRate ( ) const
The update rate is the number of times per second a sensor should generate and output data.
_hz update rate of sensor.
