Gazebo Sensors
MagnetometerSensor Class Reference
#include <MagnetometerSensor.hh>
 MagnetometerSensor ()
 constructor
virtual ~MagnetometerSensor ()
 destructor
virtual bool Init () override
math::Vector3d MagneticField () const
 Get the magnetic field vector in body frame.
void SetWorldMagneticField (const math::Vector3d &_field)
 Set the magnetic field vector in world frame.
 Set the world pose of the sensor.
 Update the sensor.
math::Vector3d WorldMagneticField () const
 Get the magnetic field vector in world frame.
 Get the world pose of the sensor.
 destructor
bool EnableMetrics () const
std::string FrameId () const
 FrameId.
SensorId Id () const
 Get the sensor's ID.
bool IsActive () const
bool IsTriggered () const
std::string Name () const
 Get name.
std::string Parent () const
 Get the current pose.
sdf::ElementPtr SDF () const
void SetActive (bool _active)
 Set Frame ID of the sensor.
 Set the parent of the sensor.
std::string Topic () const
 Update the sensor.
double UpdateRate () const
 Sensor ()
 constructor
A magnetometer reports the magnetic field vector
◆ MagnetometerSensor()
constructor
◆ ~MagnetometerSensor()
virtual ~MagnetometerSensor ( )
destructor
◆ HasConnections()
Reimplemented from Sensor.
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ MagneticField()
math::Vector3d MagneticField ( ) const
Magnetic field vector in body frame
◆ SetWorldMagneticField()
void SetWorldMagneticField ( const math::Vector3d &  _field)
[in]_fieldMagnetic field vector in world frame.
◆ SetWorldPose()
[in]_posePose in world frame
◆ Update() [1/3]
[in]_nowThe current time
Implements Sensor.
◆ Update() [2/3]
SetUpdateRate()
Implements Sensor.
◆ Update() [3/3]
const bool  _force
Update the sensor.
Remarks
◆ WorldMagneticField()
math::Vector3d WorldMagneticField ( ) const
◆ WorldPose()
Pose in world frame.
