Gazebo Sensors
NavSatSensor Class Reference
NavSat Sensor Class. More...
#include <NavSatSensor.hh>
 NavSatSensor ()
virtual ~NavSatSensor ()
double Altitude () const
 Get NavSat altitude above sea level.
virtual bool Init () override
const math::Angle & Latitude () const
 Get the latitude of the NavSat, wrapped between +/- 180 degrees.
const math::Angle & Longitude () const
 Get the longitude of the NavSat, wrapped between +/- 180 degrees.
void SetAltitude (double _altitude)
 Set the altitude of the NavSat.
void SetLatitude (const math::Angle &_latitude)
 Set the latitude of the NavSat.
void SetLongitude (const math::Angle &_longitude)
 Set the longitude of the NavSat.
void SetPosition (const math::Angle &_latitude, const math::Angle &_longitude, double _altitude=0.0)
 Easy short hand for setting the position of the sensor.
void SetVelocity (const math::Vector3d &_vel)
 Set the velocity of the NavSat in ENU world frame.
const math::Vector3d & Velocity () const
 Get the velocity of the NavSat sensor in the ENU world frame.
 destructor
bool EnableMetrics () const
std::string FrameId () const
 FrameId.
SensorId Id () const
 Get the sensor's ID.
bool IsActive () const
bool IsTriggered () const
std::string Name () const
 Get name.
std::string Parent () const
 Get the current pose.
sdf::ElementPtr SDF () const
void SetActive (bool _active)
 Set Frame ID of the sensor.
 Set the parent of the sensor.
std::string Topic () const
 Update the sensor.
double UpdateRate () const
 Sensor ()
 constructor
A sensor that reports position and velocity readings over Gazebo Transport using spherical coordinates (latitude / longitude).
By default, it publishes gz::msgs::NavSat messages on the /.../navsat topic.
This sensor assumes the world is using the East-North-Up (ENU) frame.
◆ NavSatSensor()
◆ ~NavSatSensor()
virtual ~NavSatSensor ( )
◆ Altitude()
double Altitude ( ) const
Altitude in meters
◆ HasConnections()
Reimplemented from Sensor.
virtual bool Init ( )
True on success
◆ Latitude()
const math::Angle & Latitude ( ) const
Latitude angle.
◆ Load() [1/2]
◆ Load() [2/2]
◆ Longitude()
const math::Angle & Longitude ( ) const
Longitude angle.
◆ SetAltitude()
void SetAltitude ( double  _altitude)
[in]_altitudealtitude of NavSat in meters
◆ SetLatitude()
void SetLatitude ( const math::Angle &  _latitude)
[in]_latitudeLatitude of NavSat
◆ SetLongitude()
void SetLongitude ( const math::Angle &  _longitude)
[in]_longitudeLongitude of NavSat
◆ SetPosition()
void SetPosition ( const math::Angle &  _latitude,
const math::Angle &  _longitude,
double  _altitude = 0.0
[in]_latitudeLatitude angle.
[in]_longitudeLongitude angle.
[in]_altitudeAltitude in meters; defaults to zero.
◆ SetVelocity()
void SetVelocity ( const math::Vector3d &  _vel)
[in]_velNavSat in meters per second.
[in]_nowThe current time
Implements Sensor.
◆ Velocity()
const math::Vector3d & Velocity ( ) const
Velocity in meters per second
