Gazebo Sensors
AirSpeedSensor Class Reference
AirSpeed Sensor Class. More...
#include <AirSpeedSensor.hh>
 AirSpeedSensor ()
 constructor
virtual ~AirSpeedSensor ()
 destructor
virtual bool Init () override
void SetVelocity (const gz::math::Vector3d &_vel)
 Update the velocity of the sensor.
void SetWindVelocity (const gz::math::Vector3d &_windVel)
 Update the wind velocity.
 Update the sensor.
gz::math::Vector3d Velocity () const
 Get the current velocity.
 destructor
bool EnableMetrics () const
std::string FrameId () const
 FrameId.
SensorId Id () const
 Get the sensor's ID.
bool IsActive () const
bool IsTriggered () const
std::string Name () const
 Get name.
std::string Parent () const
 Get the current pose.
sdf::ElementPtr SDF () const
void SetActive (bool _active)
 Set Frame ID of the sensor.
 Set the parent of the sensor.
std::string Topic () const
 Update the sensor.
double UpdateRate () const
 Sensor ()
 constructor
A sensor that reports air speed through differential pressure readings.
◆ AirSpeedSensor()
constructor
◆ ~AirSpeedSensor()
virtual ~AirSpeedSensor ( )
destructor
◆ HasConnections()
Reimplemented from Sensor.
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ SetVelocity()
void SetVelocity ( const gz::math::Vector3d &  _vel)
◆ SetWindVelocity()
void SetWindVelocity ( const gz::math::Vector3d &  _windVel)
◆ Update() [1/3]
[in]_nowThe current time
Implements Sensor.
◆ Update() [2/3]
SetUpdateRate()
Implements Sensor.
◆ Update() [3/3]
const bool  _force
Update the sensor.
Remarks
◆ Velocity()
gz::math::Vector3d Velocity ( ) const
Current velocity of the sensor.
