Gazebo Sensors
DepthCameraSensor Class Reference
#include <DepthCameraSensor.hh>
 DepthCameraSensor ()
 constructor
virtual ~DepthCameraSensor ()
 destructor
 Set a callback to be called when image frame data is generated.
virtual rendering::DepthCameraPtr DepthCamera () const
 Get a pointer to the rendering depth camera.
virtual double FarClip () const
 Get image width.
virtual bool HasDepthConnections () const
 Check if there are any depth subscribers.
virtual bool HasPointConnections () const
 Check if there are any point subscribers.
 Get image height.
 Get image width.
virtual bool Init () override
virtual double NearClip () const
 Get image height.
void OnNewDepthFrame (const float *_scan, unsigned int _width, unsigned int _height, unsigned int _channel, const std::string &_format)
 Depth data callback used to get the data from the sensor.
void OnNewRgbPointCloud (const float *_scan, unsigned int _width, unsigned int _height, unsigned int _channels, const std::string &_format)
 Point cloud data callback used to get the data from the sensor.
 Set the rendering scene.
 CameraSensor ()
 constructor
virtual ~CameraSensor ()
 destructor
double Baseline () const
 Get baseline for stereo cameras.
 Check if there are any image subscribers.
 Check if there are any info subscribers.
 Topic where camera info is published.
 Get the camera optical frame.
 Get pointer to rendering camera object.
 Set baseline for stereo cameras. This is used to populate the projection matrix in the camera info message.
 Set the camera info topic.
 Update the sensor.
 Set camera lens intrinsics and projection based on values from SDF. If the camera SDF does not contain intrinsic or projection parameters, the camera will not be updated. Instead, the camera SDF will be updated with intrinsic and projection values computed manually from current camera intrinsic properties.
virtual ~RenderingSensor ()
 destructor
void Render ()
 Get the rendering scene.
 destructor
bool EnableMetrics () const
std::string FrameId () const
 FrameId.
SensorId Id () const
 Get the sensor's ID.
bool IsActive () const
bool IsTriggered () const
std::string Name () const
 Get name.
std::string Parent () const
 Get the current pose.
sdf::ElementPtr SDF () const
void SetActive (bool _active)
 Set Frame ID of the sensor.
 Set the parent of the sensor.
std::string Topic () const
 Update the sensor.
double UpdateRate () const
bool AdvertiseInfo ()
 Advertise camera info topic.
 Advertise camera info topic. This version takes a string that allows one to override the camera_info topic.
 Populate camera info message.
 Publish camera info message.
 RenderingSensor ()
 constructor
 Sensor ()
 constructor
This class creates depth image from a Gazebo Rendering scene. The scene must be created in advance and given to Manager::Init(). It offers both a gz-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ DepthCameraSensor()
constructor
◆ ~DepthCameraSensor()
virtual ~DepthCameraSensor ( )
destructor
◆ ConnectImageCallback()
gz::common::ConnectionPtr ConnectImageCallback ( std::function< void(const gz::msgs::Image &)>  _callback)
Remarks
◆ DepthCamera()
virtual rendering::DepthCameraPtr DepthCamera ( ) const
Rendering depth camera
◆ FarClip()
virtual double FarClip ( ) const
Get image width.
width of the image
◆ HasConnections()
◆ HasDepthConnections()
virtual bool HasDepthConnections ( ) const
◆ HasPointConnections()
virtual bool HasPointConnections ( ) const
◆ ImageHeight()
Get image height.
height of the image
◆ ImageWidth()
Get image width.
width of the image
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ NearClip()
virtual double NearClip ( ) const
Get image height.
height of the image
◆ OnNewDepthFrame()
void OnNewDepthFrame ( const float *  _scan,
const std::string &  _format
[in]_scanpointer to the data from the sensor
[in]_widthwidth of the depth image
[in]_heightheight of the depth image
[in]_channelbytes used for the depth data
[in]_formatstring with the format
◆ OnNewRgbPointCloud()
void OnNewRgbPointCloud ( const float *  _scan,
[in]_widthwidth of the point cloud image
[in]_heightheight of the point cloud image
[in]_channelsbytes used for the point cloud data
◆ SetScene()
[in]_nowThe current time
