Gazebo Sensors
Camera Sensor Class. More...
#include <CameraSensor.hh>
 CameraSensor ()
 constructor
virtual ~CameraSensor ()
 destructor
double Baseline () const
 Get baseline for stereo cameras.
 Set a callback to be called when image frame data is generated.
 Check if there are any image subscribers.
 Check if there are any info subscribers.
virtual unsigned int ImageHeight () const
 Get image height.
virtual unsigned int ImageWidth () const
 Get image width.
 Topic where camera info is published.
virtual bool Init () override
 Get the camera optical frame.
 Get pointer to rendering camera object.
 Set baseline for stereo cameras. This is used to populate the projection matrix in the camera info message.
 Set the camera info topic.
 Set the rendering scene.
 Update the sensor.
 Set camera lens intrinsics and projection based on values from SDF. If the camera SDF does not contain intrinsic or projection parameters, the camera will not be updated. Instead, the camera SDF will be updated with intrinsic and projection values computed manually from current camera intrinsic properties.
virtual ~RenderingSensor ()
 destructor
void Render ()
 Get the rendering scene.
 destructor
bool EnableMetrics () const
std::string FrameId () const
 FrameId.
SensorId Id () const
 Get the sensor's ID.
bool IsActive () const
bool IsTriggered () const
std::string Name () const
 Get name.
std::string Parent () const
 Get the current pose.
sdf::ElementPtr SDF () const
void SetActive (bool _active)
 Set Frame ID of the sensor.
 Set the parent of the sensor.
std::string Topic () const
 Update the sensor.
double UpdateRate () const
bool AdvertiseInfo ()
 Advertise camera info topic.
 Advertise camera info topic. This version takes a string that allows one to override the camera_info topic.
 Populate camera info message.
 Publish camera info message.
 RenderingSensor ()
 constructor
 Sensor ()
 constructor
This class creates images from a Gazebo Rendering scene. The scene must be created in advance and given to Manager::Init(). It offers both a gz-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ CameraSensor()
constructor
◆ ~CameraSensor()
virtual ~CameraSensor ( )
destructor
◆ AdvertiseInfo() [1/2]
bool AdvertiseInfo ( )
True if successful.
◆ AdvertiseInfo() [2/2]
bool AdvertiseInfo ( const std::string &  _topic)
[in]_topicThe topic on which camera info is to be published.
True if successful.
◆ Baseline()
double Baseline ( ) const
The distance from the 1st camera, in meters.
◆ ConnectImageCallback()
gz::common::ConnectionPtr ConnectImageCallback ( std::function< void(const gz::msgs::Image &)>  _callback)
Remarks
◆ HasConnections()
Reimplemented from Sensor.
Reimplemented in BoundingBoxCameraSensor, DepthCameraSensor, RgbdCameraSensor, SegmentationCameraSensor, ThermalCameraSensor, and WideAngleCameraSensor.
◆ HasImageConnections()
virtual bool HasImageConnections ( ) const
True if there are image subscribers, false otherwise
◆ HasInfoConnections()
virtual bool HasInfoConnections ( ) const
True if there are info subscribers, false otherwise
◆ ImageHeight()
◆ ImageWidth()
◆ InfoTopic()
std::string InfoTopic ( ) const
Camera info topic.
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ OpticalFrameId()
const std::string & OpticalFrameId ( ) const
The camera optical frame
◆ PopulateInfo()
void PopulateInfo ( const sdf::Camera *  _cameraSdf)
[in]_cameraSdfPointer to SDF object containing camera information.
◆ PublishInfo()
void PublishInfo ( const std::chrono::steady_clock::duration &  _now)
[in]_nowThe current time
◆ RenderingCamera()
virtual rendering::CameraPtr RenderingCamera ( ) const
Camera in Gazebo Rendering.
Reimplemented in WideAngleCameraSensor.
◆ SetBaseline()
void SetBaseline ( double  _baseline)
[in]_baselineThe distance from the 1st camera, in meters.
◆ SetInfoTopic()
bool SetInfoTopic ( const std::string &  _topic)
[in]_topicTopic sensor publishes camera info data to.
True if a valid topic was set.
◆ SetScene()
Reimplemented in DepthCameraSensor, RgbdCameraSensor, SegmentationCameraSensor, ThermalCameraSensor, and WideAngleCameraSensor.
◆ Update() [1/3]
Implements Sensor.
◆ Update() [2/3]
SetUpdateRate()
Implements Sensor.
◆ Update() [3/3]
const bool  _force
Update the sensor.
Remarks
◆ UpdateLensIntrinsicsAndProjection()
void UpdateLensIntrinsicsAndProjection ( rendering::CameraPtr  _camera,
sdf::Camera &  _cameraSdf
[in]_cameraCamera to set intrinsic and projection params.
[in,out]_cameraSdfCamera sdf with intrinisc and projection parameters.
