Gazebo Sensors
ImuSensor Class Reference
Imu Sensor Class. More...
#include <ImuSensor.hh>
 ImuSensor ()
 constructor
virtual ~ImuSensor ()
 destructor
math::Vector3d AngularVelocity () const
 Get the angular velocity of the imu.
math::Vector3d Gravity () const
 Get the gravity vector.
virtual bool Init () override
math::Vector3d LinearAcceleration () const
 Get the linear acceleration of the imu.
math::Quaterniond Orientation () const
 Get the orienation of the imu with respect to reference frame.
bool OrientationEnabled () const
 Get whether or not orientation is enabled.
math::Quaterniond OrientationReference () const
 Get the world orienation reference of the imu.
void SetAngularVelocity (const math::Vector3d &_angularVel)
 Set the angular velocity of the imu.
void SetGravity (const math::Vector3d &_gravity)
 Set the gravity vector.
void SetLinearAcceleration (const math::Vector3d &_linearAcc)
 Set the linear acceleration of the imu.
void SetOrientationEnabled (bool _enabled)
 Set whether to output orientation. Not all imu's generate orientation values as they use filters to produce orientation estimates.
void SetOrientationReference (const math::Quaterniond &_orient)
 Set the orientation reference, i.e. initial imu orientation. Imu orientation data generated will be relative to this reference frame.
void SetWorldFrameOrientation (const math::Quaterniond &_rot, WorldFrameEnumType _relativeTo)
 Specify the rotation offset of the coordinates of the World frame relative to a geo-referenced frame.
 Set the world pose of the imu.
 Update the sensor.
 Get the world pose of the imu.
 destructor
bool EnableMetrics () const
std::string FrameId () const
 FrameId.
SensorId Id () const
 Get the sensor's ID.
bool IsActive () const
bool IsTriggered () const
std::string Name () const
 Get name.
std::string Parent () const
 Get the current pose.
sdf::ElementPtr SDF () const
void SetActive (bool _active)
 Set Frame ID of the sensor.
 Set the parent of the sensor.
std::string Topic () const
 Update the sensor.
double UpdateRate () const
 Sensor ()
 constructor
Imu Sensor Class.
An imu sensor that reports linear acceleration, angular velocity, and orientation
◆ ImuSensor()
ImuSensor ( )
constructor
◆ ~ImuSensor()
virtual ~ImuSensor ( )
destructor
◆ AngularVelocity()
math::Vector3d AngularVelocity ( ) const
Angular velocity of the imu in body frame, expressed in radians per second.
◆ Gravity()
math::Vector3d Gravity ( ) const
Gravity vectory in meters per second squared.
◆ HasConnections()
Reimplemented from Sensor.
virtual bool Init ( )
True on success
◆ LinearAcceleration()
math::Vector3d LinearAcceleration ( ) const
Linear acceleration of the imu in local frame, expressed in meters per second squared.
◆ Load() [1/2]
◆ Load() [2/2]
◆ Orientation()
math::Quaterniond Orientation ( ) const
Orientation in reference frame. If orientation is not enabled, this will return the last computed orientation before orientation is disabled or identity Quaternion if orientation has never been enabled.
◆ OrientationEnabled()
bool OrientationEnabled ( ) const
True if orientation is enabled, false otherwise.
◆ OrientationReference()
math::Quaterniond OrientationReference ( ) const
Orientation reference in world frame
◆ SetAngularVelocity()
void SetAngularVelocity ( const math::Vector3d &  _angularVel)
[in]_angularVelAngular velocity of the imu in body frame expressed in radians per second
◆ SetGravity()
void SetGravity ( const math::Vector3d &  _gravity)
[in]_gravitygravity vector in meters per second squared.
◆ SetLinearAcceleration()
void SetLinearAcceleration ( const math::Vector3d &  _linearAcc)
[in]_linearAccLinear accceleration of the imu in body frame expressed in meters per second squared.
◆ SetOrientationEnabled()
void SetOrientationEnabled ( bool  _enabled)
[in]_enabledTrue to publish orientation data, false to leave the message field empty.
◆ SetOrientationReference()
void SetOrientationReference ( const math::Quaterniond &  _orient)
[in]_orientReference orientation
◆ SetWorldFrameOrientation()
void SetWorldFrameOrientation ( const math::Quaterniond &  _rot,
[in]_rotrotation offset
[in]_relativeToworld frame orientation, ENU by default
◆ SetWorldPose()
[in]_posePose in world frame
◆ Update() [1/3]
[in]_nowThe current time
Implements Sensor.
◆ Update() [2/3]
SetUpdateRate()
Implements Sensor.
◆ Update() [3/3]
const bool  _force
Update the sensor.
Remarks
◆ WorldPose()
Pose in world frame.
