TestFixture Class Reference
Helper class to write automated tests. It provides a convenient API to load a world file, step simulation and check entities and components. More...
#include <TestFixture.hh>
 TestFixture (const ServerConfig &_config)
 TestFixture (const std::string &_path)
virtual ~TestFixture ()=default
TestFixture & Finalize ()
 Finalize all the functions and add fixture to server. Finalize must be called before running the server, otherwise none of the On* functions will be called. The OnConfigure callback is called immediately on finalize.
TestFixture & OnConfigure (std::function< void(const Entity &_entity, const std::shared_ptr< const sdf::Element > &_sdf, EntityComponentManager &_ecm, EventManager &_eventMgr)> _cb)
 Wrapper around a system's pre-update callback.
TestFixture & OnPostUpdate (std::function< void(const UpdateInfo &, const EntityComponentManager &)> _cb)
 Wrapper around a system's post-update callback.
TestFixture & OnPreUpdate (std::function< void(const UpdateInfo &, EntityComponentManager &)> _cb)
TestFixture & OnReset (std::function< void(const UpdateInfo &, EntityComponentManager &)> _cb)
 Wrapper around a system's update callback.
TestFixture & OnUpdate (std::function< void(const UpdateInfo &, EntityComponentManager &)> _cb)
std::shared_ptr< sim::Server > Server () const
 Get pointer to underlying server.
Usage
// Load a world with a fixture
TestFixture fixture("path_to.sdf");
// Register callbacks, for example:
fixture.OnPostUpdate([&](const sim::UpdateInfo &,
// Add expectations here
}).Finalize();
// Be sure to call finalize before running the server.
// Run the server
fixture.Server()->Run(true, 1000, false);
◆ TestFixture() [1/2]
TestFixture ( const std::string &  _path)
[in]_pathPath to SDF file.
◆ TestFixture() [2/2]
TestFixture ( const ServerConfig &  _config)
[in]_configServer config file
◆ ~TestFixture()
virtual ~TestFixture ( )
virtualdefault
◆ Finalize()
TestFixture & Finalize ( )
◆ OnConfigure()
TestFixture & OnConfigure ( std::function< void(const Entity &_entity, const std::shared_ptr< const sdf::Element > &_sdf, EntityComponentManager &_ecm, EventManager &_eventMgr)>  _cb)
[in]_cbFunction to be called every pre-update The _entity and _sdf will correspond to the world entity.
Reference to self.
◆ OnPostUpdate()
TestFixture & OnPostUpdate ( std::function< void(const UpdateInfo &, const EntityComponentManager &)>  _cb)
[in]_cbFunction to be called every post-update
Reference to self.
◆ OnPreUpdate()
TestFixture & OnPreUpdate ( std::function< void(const UpdateInfo &, EntityComponentManager &)>  _cb)
Reference to self.
◆ OnReset()
TestFixture & OnReset ( std::function< void(const UpdateInfo &, EntityComponentManager &)>  _cb)
[in]_cbFunction to be called every reset
Reference to self.
◆ OnUpdate()
TestFixture & OnUpdate ( std::function< void(const UpdateInfo &, EntityComponentManager &)>  _cb)
[in]_cbFunction to be called every update
Reference to self.
◆ Server()
