Creates an ignition rendering scene and user camera. It is possible to orbit the camera around the scene with the mouse. Use other plugins to manage objects in the scene. More...
#include <Scene3D.hh>
Public Slots
void OnDropped (const QString &_drop, int _mouseX, int _mouseY)
 Callback when receives a drop event. More...
void OnFocusWindow ()
 Callback when the mouse enters the render window to focus the window for mouse/key events. More...
void OnHovered (int _mouseX, int _mouseY)
 Callback when the mouse hovers to a new position. More...
Signals
void ErrorPopupTextChanged ()
 Notify the popup error text has changed. More...
void LoadingErrorChanged ()
 Notify that loading error has changed. More...
void popupError ()
 Notify that an error has occurred (opens popup) Note that the function name needs to start with lowercase in order for the connection to work on the QML side. More...
 Scene3D ()
 ~Scene3D () override
Q_INVOKABLE QString ErrorPopupText () const
 Get the text for the popup error message. More...
Q_INVOKABLE QString LoadingError () const
 Get the loading error string. More...
Q_INVOKABLE void SetErrorPopupText (const QString &_errorTxt)
 Set the text for the popup error message. More...
Q_INVOKABLE void SetLoadingError (const QString &_loadingError)
 Set the loading error message. More...
 Update callback called every time the system is stepped. This is called at an Ignition transport thread, so any interaction with Qt should be done through signals and slots. More...
Properties
QString errorPopupText
 Text for popup error. More...
QString loadingError
 Loading error message. More...
Only one plugin displaying an Ignition Rendering scene can be used at a time.
Configuration
  • <engine> : Optional render engine name, defaults to 'ogre'.
  • <scene> : Optional scene name, defaults to 'scene'. The plugin will create a scene with this name if there isn't one yet. If there is already one, a new camera is added to it.
  • <ambient_light> : Optional color for ambient light, defaults to (0.3, 0.3, 0.3, 1.0)
  • <background_color> : Optional background color, defaults to (0.3, 0.3, 0.3, 1.0)
  • <camera_pose> : Optional starting pose for the camera, defaults to (0, 0, 5, 0, 0, 0)
  • <camera_follow> :
    • <p_gain> : Camera follow movement p gain.
    • <target> : Target to follow.
  • <fullscreen> : Optional starting the window in fullscreen.
◆ Scene3D()
Scene3D ( )
◆ ~Scene3D()
~Scene3D ( )
◆ ErrorPopupText()
Q_INVOKABLE QString ErrorPopupText ( ) const
The error text
◆ ErrorPopupTextChanged
void ErrorPopupTextChanged ( )
signal
◆ eventFilter()
QEvent *  _event
overrideprotected
◆ LoadConfig()
◆ LoadingError()
Q_INVOKABLE QString LoadingError ( ) const
String explaining the loading error. If empty, there's no error.
◆ LoadingErrorChanged
void LoadingErrorChanged ( )
signal
◆ OnDropped
void OnDropped ( const QString &  _drop,
int  _mouseX,
int  _mouseY
slot
[in]_dropDropped string.
[in]_mouseXx coordinate of mouse position.
[in]_mouseYy coordinate of mouse position.
◆ OnFocusWindow
void OnFocusWindow ( )
slot
◆ OnHovered
void OnHovered ( int  _mouseX,
int  _mouseY
slot
[in]_mouseXx coordinate of the hovered mouse position.
[in]_mouseYy coordinate of the hovered mouse position.
◆ popupError
void popupError ( )
signal
◆ SetErrorPopupText()
Q_INVOKABLE void SetErrorPopupText ( const QString &  _errorTxt)
[in]_errorTxtThe error text
◆ SetLoadingError()
Q_INVOKABLE void SetLoadingError ( const QString &  _loadingError)
[in]_loadingErrorError message.
Reimplemented from GuiSystem.
Property Documentation
◆ errorPopupText
readwrite
◆ loadingError
readwrite
