GuiSystem Class Reference
Base class for a GUI System. More...
#include <GuiSystem.hh>
virtual void Update (const UpdateInfo &_info, EntityComponentManager &_ecm)
 Update callback called every time the system is stepped. This is called at an Ignition transport thread, so any interaction with Qt should be done through signals and slots. More...
A System operates on Entities that have certain Components. A System will only operate on an Entity if it has all of the required Components.
GUI systems are different from gz::sim::Systems because they don't run in the same process as the physics. Instead, they run in a separate process that is stepped by updates coming through the network
virtual void Update ( const UpdateInfo &  _info,
inlinevirtual
Reimplemented in Plot3D, Scene3D, AlignTool, EntityTree, and PlaybackScrubber.
