Provides buttons for the tape measure tool. More...
#include <TapeMeasure.hh>
Public Slots
double Distance ()
 Callback in Qt thread to get the distance to display in the gui window. More...
void OnMeasure ()
 Callback in Qt thread when the new measurement button is clicked. More...
void OnReset ()
 Callback in Qt thread when the reset button is clicked. More...
Signals
void newDistance ()
 Signal fired when a new tape measure distance is set. More...
 TapeMeasure ()
 ~TapeMeasure () override
void DeleteMarker (int _id)
 Deletes the marker with the provided id within the "tape_measure" namespace. More...
void DrawLine (int _id, gz::math::Vector3d &_startPoint, gz::math::Vector3d &_endPoint, gz::math::Color &_color)
 Draws a line marker. Called to display the line between the start and end point of the tape measure. More...
void DrawPoint (int _id, gz::math::Vector3d &_point, gz::math::Color &_color)
 Draws a point marker. Called to display the start and end point of the tape measure. More...
void Measure ()
 Starts a new measurement. Erases any previous measurement in progress or already made. More...
void Reset ()
 Resets all of the relevant data for this plugin. Called when the user clicks the reset button and when the user starts a new measurement. More...
◆ TapeMeasure()
◆ ~TapeMeasure()
~TapeMeasure ( )
◆ DeleteMarker()
void DeleteMarker ( int  _id)
[in]_idThe id of the marker
◆ Distance
double Distance ( )
slot
The distance between the start and end point of the measurement
◆ DrawLine()
void DrawLine ( int  _id,
gz::math::Vector3d &  _startPoint,
gz::math::Vector3d &  _endPoint,
gz::math::Color &  _color
[in]_startPointThe x, y, z coordinates of the line start point
[in]_endPointThe x, y, z coordinates of the line end point
[in]_colorThe rgba color to set the marker
◆ DrawPoint()
void DrawPoint ( int  _id,
gz::math::Vector3d &  _point,
[in]_pointThe x, y, z coordinates of where to place the marker
◆ eventFilter()
QEvent *  _event
overrideprotected
◆ LoadConfig()
◆ Measure()
void Measure ( )
◆ newDistance
void newDistance ( )
signal
◆ OnMeasure
void OnMeasure ( )
slot
◆ OnReset
void OnReset ( )
slot
◆ Reset()
void Reset ( )
