#include <gz/math/Vector3.hh>
#include <gz/sim/config.hh>
| ignition |
| This library is part of the Ignition Robotics project.
| ignition::gazebo |
| Gazebo is a leading open source robotics simulator, that provides high fidelity physics, rendering, and sensor simulation.
| ignition::gazebo::components |
| Components represent data, such as position information. An Entity usually has one or more associated components.
using | AngularVelocityCmd = Component< math::Vector3d, class AngularVelocityCmdTag > |
| A component type that contains the commanded angular velocity of an entity, in its own frame, represented by gz::math::Vector3d. More...
| IGN_GAZEBO_REGISTER_COMPONENT ("ign_gazebo_components.AngularAcceleration", AngularAcceleration) using WorldAngularAcceleration |
| A component type that contains angular acceleration of an entity in the world frame represented by gz::math::Vector3d. More...
