gz/sim/components/ExternalWorldWrenchCmd.hh File Reference
#include <gz/msgs/wrench.pb.h>
#include <gz/sim/config.hh>
 ignition
 ignition::gazebo
 ignition::gazebo::components
using ExternalWorldWrenchCmd = Component< msgs::Wrench, class ExternalWorldWrenchCmdTag, serializers::MsgSerializer >
 A component type that contains the external wrench to be applied on an entity expressed in the world frame and represented by gz::msgs::Wrench. Currently this is used for applying wrenches on links. Although the msg::Wrench type has a force_offset member, the value is currently ignored. Instead, the force is applied at the link origin. The wrench uses SI units (N for force and N⋅m for torque). More...
