gz/sim/components/JointType.hh File Reference
#include <memory>
#include <sdf/Joint.hh>
#include <gz/sim/config.hh>
Classes | |
class | JointTypeSerializer |
Namespaces | |
ignition | |
This library is part of the Ignition Robotics project. | |
ignition::gazebo | |
ignition::gazebo::components | |
Components represent data, such as position information. An Entity usually has one or more associated components. | |
ignition::gazebo::serializers | |
A Serializer class is used to serialize and deserialize a component. It is passed in as the third template parameter to components::Component. Eg. | |
Typedefs | |
using | JointType = Component< sdf::JointType, class JointTypeTag, serializers::JointTypeSerializer > |
A component that contains the joint type. This is a simple wrapper around sdf::JointType. More... | |
