gz/sim/components/JointType.hh
17 #ifndef GZ_GAZEBO_COMPONENTS_JOINTTYPE_HH_
18 #define GZ_GAZEBO_COMPONENTS_JOINTTYPE_HH_
20 #include <memory>
21 #include <sdf/Joint.hh>
25
26 namespace ignition
27 {
28 namespace gazebo
29 {
32 namespace serializers
33 {
35  {
40  public: static std::ostream &Serialize(std::ostream &_out,
41  const sdf::JointType &_type)
42  {
43  _out << static_cast<int>(_type);
44  return _out;
45  }
46
51  public: static std::istream &Deserialize(std::istream &_in,
52  sdf::JointType &_type)
53  {
54  int type;
55  _in >> type;
56  _type = sdf::JointType(type);
57  return _in;
58  }
59  };
60 }
61 namespace components
62 {
65  using JointType = Component<sdf::JointType, class JointTypeTag,
66  serializers::JointTypeSerializer>;
68  "ign_gazebo_components.JointType", JointType)
69 }
70 }
71 }
72 }
73
74 #endif
Component< sdf::JointType, class JointTypeTag, serializers::JointTypeSerializer > JointType
A component that contains the joint type. This is a simple wrapper around sdf::JointType.
Definition: gz/sim/components/JointType.hh:66
static std::ostream & Serialize(std::ostream &_out, const sdf::JointType &_type)
Serialization for sdf::JointType.
Definition: gz/sim/components/JointType.hh:40
static std::istream & Deserialize(std::istream &_in, sdf::JointType &_type)
Deserialization for sdf::JointType.
Definition: gz/sim/components/JointType.hh:51
Definition: gz/sim/components/JointType.hh:34
STL class.
STL class.
