gz/sim/components/LevelEntityNames.hh
17 #ifndef GZ_GAZEBO_COMPONENTS_LEVELENTITYNAMES_HH_
18 #define GZ_GAZEBO_COMPONENTS_LEVELENTITYNAMES_HH_
20 #include <iterator>
21 #include <string>
22 #include <set>
24 #include <gz/sim/Export.hh>
25
28
29 namespace ignition
30 {
31 namespace gazebo
32 {
34 inline namespace IGNITION_GAZEBO_VERSION_NAMESPACE {
35 namespace serializers
36 {
38  {
43  public: static std::ostream &Serialize(std::ostream &_out,
44  const std::set<std::string> &_set)
45  {
46  for (const auto &entity : _set)
47  {
48  _out << entity << " ";
49  }
50  return _out;
51  }
52
57  public: static std::istream &Deserialize(std::istream &_in,
59  {
60  _in.setf(std::ios_base::skipws);
61
62  _set.clear();
63
64  for (auto it = std::istream_iterator<std::string>(_in);
66  {
67  _set.insert(*it);
68  }
69  return _in;
70  }
71  };
72 }
73
74 namespace components
75 {
78  using LevelEntityNames =
79  Component<std::set<std::string>, class LevelEntityNamesTag,
80  serializers::LevelEntityNamesSerializer>;
81
82  IGN_GAZEBO_REGISTER_COMPONENT("ign_gazebo_components.LevelEntityNames",
83  LevelEntityNames)
84 }
85 }
86 }
87 }
88 #endif
89
T clear(T... args)
static std::istream & Deserialize(std::istream &_in, std::set< std::string > &_set)
Deserialization for std::set<std::string>.
Definition: gz/sim/components/LevelEntityNames.hh:57
Component< std::set< std::string >, class LevelEntityNamesTag, serializers::LevelEntityNamesSerializer > LevelEntityNames
A component that holds a list of names of entities to be loaded in a level.
Definition: gz/sim/components/LevelEntityNames.hh:80
STL class.
Definition: gz/sim/components/LevelEntityNames.hh:37
T setf(T... args)
static std::ostream & Serialize(std::ostream &_out, const std::set< std::string > &_set)
Serialization for std::set<std::string>.
Definition: gz/sim/components/LevelEntityNames.hh:43
T insert(T... args)
STL class.
