gz/sim/components/LinearVelocitySeed.hh File Reference
#include <gz/math/Vector3.hh>
#include <gz/sim/config.hh>
 ignition
 ignition::gazebo
 ignition::gazebo::components
using LinearVelocitySeed = Component< math::Vector3d, class LinearVelocitySeedTag >
 A component type that contains linear velocity seed of an entity expressed in the local frame of the entity and represented by gz::math::Vector3d. This seed can used to generate linear velocities by applying transformations and adding noise. More...
Functions
 IGN_GAZEBO_REGISTER_COMPONENT ("ign_gazebo_components.AngularAcceleration", AngularAcceleration) using WorldAngularAcceleration
 A component type that contains angular acceleration of an entity in the world frame represented by gz::math::Vector3d. More...
