gz/sim/components/PerformerLevels.hh
17 #ifndef GZ_GAZEBO_COMPONENTS_PERFORMERLEVELS_HH_
18 #define GZ_GAZEBO_COMPONENTS_PERFORMERLEVELS_HH_
20 #include <set>
21 #include <gz/sim/config.hh>
22 #include <gz/sim/Export.hh>
23
24 #include "gz/sim/Entity.hh"
27
28 namespace ignition
29 {
30 namespace gazebo
31 {
34 namespace serializers
35 {
37  {
42  public: static std::ostream &Serialize(std::ostream &_out,
43  const std::set<Entity> &_set)
44  {
45  for (const auto &level : _set)
46  {
47  _out << level << " ";
48  }
49  return _out;
50  }
51
56  public: static std::istream &Deserialize(std::istream &_in,
57  std::set<Entity> &_set)
58  {
59  _in.setf(std::ios_base::skipws);
60
61  _set.clear();
62
63  for (auto it = std::istream_iterator<Entity>(_in);
64  it != std::istream_iterator<Entity>(); ++it)
65  {
66  _set.insert(*it);
67  }
68  return _in;
69  }
70  };
71 }
72
73 namespace components
74 {
76  using PerformerLevels = Component<std::set<Entity>, class PerformerLevelsTag,
77  serializers::PerformerLevelsSerializer>;
78  IGN_GAZEBO_REGISTER_COMPONENT("ign_gazebo_components.PerformerLevels",
79  PerformerLevels)
80 }
81 }
82 }
83 }
84 #endif
85
static std::istream & Deserialize(std::istream &_in, std::set< Entity > &_set)
Deserialization for std::set<Entity>.
Definition: gz/sim/components/PerformerLevels.hh:56
static std::ostream & Serialize(std::ostream &_out, const std::set< Entity > &_set)
Serialization for std::set<Entity>.
Definition: gz/sim/components/PerformerLevels.hh:42
T clear(T... args)
STL class.
Component< std::set< Entity >, class PerformerLevelsTag, serializers::PerformerLevelsSerializer > PerformerLevels
Holds all the levels which a performer is in.
Definition: gz/sim/components/PerformerLevels.hh:77
T setf(T... args)
Definition: gz/sim/components/PerformerLevels.hh:36
T insert(T... args)
STL class.
