DetachableJoint Class Reference
A system that initially attaches two models via a fixed joint and allows for the models to get detached during simulation via a topic. A model can be re-attached during simulation via a topic. The status of the detached state can be monitored via a topic as well. More...
#include <DetachableJoint.hh>
 DetachableJoint ()=default
Parameters:
  • <parent_link>: Name of the link in the parent model to be used in creating a fixed joint with a link in the child model.
  • <child_model>: Name of the model to which this model will be connected
  • <child_link>: Name of the link in the child model to be used in creating a fixed joint with a link in the parent model.
  • <topic> (optional): Topic name to be used for detaching connections. Using <detach_topic> is preferred.
  • <detach_topic> (optional): Topic name to be used for detaching connections. If multiple detachable plugin is used in one model, detach_topic is REQUIRED to detach child models individually.
  • <attach_topic> (optional): Topic name to be used for attaching connections. If multiple detachable plugin is used in one model, attach_topic is REQUIRED to attach child models individually.
  • <output_topic> (optional): Topic name to be used for publishing the state of the detachment. If multiple detachable plugin is used in one model, output_topic is REQUIRED to publish child models state individually.
  • <suppress_child_warning> (optional): If true, the system will not print a warning message if a child model does not exist yet. Otherwise, a warning message is printed. Defaults to false.
◆ DetachableJoint()
DetachableJoint ( )
default
finalvirtual
finalvirtual
