ParticleEmitter Class Reference
A system for running and managing particle emitters. A particle emitter is defined using the <particle_emitter> SDF element. More...
#include <ParticleEmitter.hh>
 ParticleEmitter ()
 Configure the system. More...
This system will create a transport subscriber for each <particle_emitter> using the child <topic> name. If a <topic> is not specified, the following topic naming scheme will be used: /model/{model_name}/link/{link_name}/particle_emitter/{emitter_name}/cmd
◆ ParticleEmitter()
