Sensors Class Reference
A system that manages sensors. More...
#include <gz/sim/systems/Sensors.hh>
 Sensors ()
 ~Sensors () override
void Configure (const Entity &_id, const std::shared_ptr< const sdf::Element > &_sdf, EntityComponentManager &_ecm, EventManager &_eventMgr) final
 Configure the system. More...
  • <render_engine> Name of the render engine, such as 'ogre' or 'ogre2'.
  • <background_color> Color used for the scene's background. This will override the background color specified in a world's SDF <scene> element. This background color is used by sensors, not the GUI.
  • <ambient_light> Color used for the scene's ambient light. This will override the ambient value specified in a world's SDF <scene> element. This ambient light is used by sensors, not the GUI.
  • <disable_on_drained_battery> Disable sensors if the model's battery plugin charge reaches zero. Sensors that are in nested models are also affected.
\TODO(louise) Have one system for all sensors, or one per sensor / sensor type?
◆ Sensors()
Sensors ( )
◆ ~Sensors()
~Sensors ( )
finalvirtual
◆ PostUpdate()
finalvirtual
◆ Reset()
finalvirtual
Implements ISystemReset.
finalvirtual
Implements ISystemUpdate.
