ShaderParam Class Reference
A plugin for setting shaders to a visual and its params. More...
#include <ShaderParam.hh>
 ShaderParam ()
 ~ShaderParam () override
 Configure the system. More...
Plugin parameters:
<shader> Shader to use - can be repeated to specify shader programs written in different languages. Attributes: language - Shader language. Possible values: glsl, metal Default to glsl if not specified <vertex> Path to vertex program <fragment> Path to fragment program Shader parameter - can be repeated within plugin SDF element <name> Name of uniform variable bound to the shader <shader> Type of shader, i.e. vertex, fragment <type> Variable type: float, int, float_array, int_array
Value to set the shader parameter to. The vallue string can be an int, float, or a space delimited array of ints or floats. It can also be 'TIME', in which case the value will be bound to sim time.
Example usage:
///     <plugin filename="gz-sim-shader-param-system"
///             name="systems::ShaderParam">
///        <shader language='glsl'>
///          <vertex>materials/my_vs.glsl</vertex>
///          <fragment>materials/my_fs.glsl</fragment>
///        </shader>
///        <!-- Sets a fragment shader variable named "ambient" to red -->
///        <param>
///          <name>ambient</name>
///          <shader>fragment</shader>
///          <type>float_array</type>
///          <value>1.0 0.0 0.0 1.0</value>
///        </param>
///    </plugin>
◆ ShaderParam()
◆ ~ShaderParam()
~ShaderParam ( )
finalvirtual
