WindEffects Class Referencefinal
A system that simulates a simple wind model. The wind is described as a uniform worldwide model. Its components are computed separately: More...
#include <WindEffects.hh>
 WindEffects ()
 ~WindEffects () final
 Configure the system. More...
  • Horizontal amplitude: Low pass filtering on user input (complementary gain)
    • small local fluctuations
    • noise on value (noise amplitude is a factor of wind magnitude)
  • Horizontal direction: Low pass filtering on user input (complementary gain)
    • noise on value
  • Vertical amplitude: Low pass filtering on user input (complementary gain)
    • noise on value
Forces exerted by the wind on model links are approximated from link mass and velocity with respect to wind velocity, and applied to the link frame origin. These approximations can be amplified or attenuated on a per location basis by specifying a piecewise scalar field for a scaling factor.
The following parameters are used by the system:
  • <horizontal><magnitude><time_for_rise> Analogous to the time constant of the low pass filter.
  • <horizontal><magnitude><sin><amplitude_percent> Fraction of the filtered wind velocity magnitude that is set to be the amplitude of the sinusoid.
  • <horizontal><magnitude><sin><period> Period of the sinusoid that is added to the wind velocity magnitude.
  • <horizontal><magnitude><noise> Parameters for the noise that is added to the wind velocity magnitude.
  • <horizontal><direction><time_for_rise> Analogous to the time constant of the low pass filter.
  • <horizontal><direction><sin><amplitude> Amplitude of the sinusoidal that is added on the direction of the wind velocity.
  • <horizontal><direction><sin><period> Period of the sinusoid that is added to the wind velocity direction.
  • <horizontal><direction><noise> Parameters for the noise that is added to the wind velocity direction.
  • <vertical><time_for_rise> Analogous to the time constant of the low pass filter for the vertical wind velocity magnitude.
  • <vertical><noise> Parameters for the noise that is added to the vertical wind velocity magnitude.
  • <force_approximation_scaling_factor> Proportionality constant used for wind force approximations as a piecewise, separable scalar field:
    ///   <force_approximation_scaling_factor>
    ///     <when xlt="0"> <!-- Half space where x < 0 -->
    ///       <k>1</k>
    ///       <px>0 0 0 1</px>  <!-- p(x) = x -->
    ///       <qy>0 0 0 1</qy>  <!-- q(y) = 1 -->
    ///       <rz>0 1 0 1</rz>  <!-- r(z) = z^2 -->
    ///     </when>
    ///   </force_approximation_scaling_factor>
    When the scaling factor is to be constant in a region, a numerical constant may be used in place for the scalar field definition:
    ///     <!-- First octant -->
    ///     <when xge="0" yge="0" zge="0">1</when>
    To use the same constant or scalar field in all space, region definition may be dropped:
    ///     <k>2</k>
    ///     <px>1 0 1 0</px>  <!-- p(x) = x^3 + x -->
    ///     <qy>0 1 0 1</qy>  <!-- q(y) = x^2 + 1 -->
    ///     <rz>1 0 1 0</rz>  <!-- r(z) = z^3 + z -->
    Regions may not overlap.
◆ WindEffects()
◆ ~WindEffects()
~WindEffects ( )
final
finalvirtual
finalvirtual
