ShaderParam Class Reference
A plugin for setting shaders to a visual and its params. More...
#include <ShaderParam.hh>
 ShaderParam ()
 ~ShaderParam () override
 Configure the system. More...
  • <shader>: Shader to use - can be repeated to specify shader programs written in different languages.
    • Attributes:
      • language: Shader language. Possible values: glsl, metal Default to glsl if not specified
    • <vertex>: Path to vertex program
    • <fragment>: Path to fragment program
  • <param>: Shader parameter - can be repeated within plugin SDF element
    • <name>: Name of uniform variable bound to the shader
    • <shader>: Type of shader, i.e. vertex, fragment
    • <type>: Variable type: float, int, float_array, int_array
    • <value>: Value to set the shader parameter to. The vallue string can be an int, float, or a space delimited array of ints or floats. It can also be "TIME", in which case the value will be bound to sim time.
Example
<plugin filename="gz-sim-shader-param-system"
name="systems::ShaderParam">
<shader language='glsl'>
<vertex>materials/my_vs.glsl</vertex>
<fragment>materials/my_fs.glsl</fragment>
</shader>
<!-- Sets a fragment shader variable named "ambient" to red -->
<param>
<name>ambient</name>
<shader>fragment</shader>
<type>float_array</type>
<value>1.0 0.0 0.0 1.0</value>
</param>
◆ ShaderParam()
◆ ~ShaderParam()
~ShaderParam ( )
finalvirtual
