EntityContextMenuItem Class Reference
A QQUickItem that manages the render window. More...
#include <EntityContextMenuPlugin.hh>
Public Slots
void OnContextMenuRequested (QString _entity, int _mouseX, int _mouseY)
 Qt callback when context menu request is received.
Signals
void openContextMenu (QString _entity, int _mouseX, int _mouseY)
 Signal fired to open context menu Note that the function name needs to start with lowercase in order for the connection to work on the QML side.
 EntityContextMenuItem (QQuickItem *_parent=nullptr)
void SetEntityContextMenuHandler (const EntityContextMenuHandler &_entityContextMenuHandler)
 Set the entity context menu handler.
◆ EntityContextMenuItem()
EntityContextMenuItem ( QQuickItem *  _parent = nullptr)
[in]_parentParent item
◆ OnContextMenuRequested
void OnContextMenuRequested ( QString  _entity,
int  _mouseX,
int  _mouseY
slot
[in]_entityScoped name of entity.
[in]_mouseXX coordinate of the right click
[in]_mouseYY coordinate of the right click
◆ openContextMenu
void openContextMenu ( QString  _entity,
int  _mouseX,
int  _mouseY
signal
◆ SetEntityContextMenuHandler()
void SetEntityContextMenuHandler ( const EntityContextMenuHandler &  _entityContextMenuHandler)
[in]_entityContextMenuHandlerEntity context menu handler
