Ogre implementation of the RenderPass class. More...
#include <OgreRenderPass.hh>
virtual ~OgreRenderPass ()
virtual void CreateRenderPass ()
 Create the render pass using ogre compositor.
void Destroy () override
 Set the ogre camera that the render pass applies to.
virtual void SetCameras (Ogre::Camera *_cameras[kMaxOgreRenderPassCameras])
 Set all ogre cameras that the render pass applies to at once.
virtual ~BaseRenderPass ()
virtual ~RenderPass ()
 OgreRenderPass ()
 BaseRenderPass ()
virtual void Init ()
Ogre::Camera * ogreCamera [kMaxOgreRenderPassCameras] = {}
 Pointer to the ogre camera May have more than one. Must check for nullptr on all of them. Not all RenderPasses support multiple cameras.
bool afterStitching
 Flag tracking the current value of SetWideAngleCameraAfterStitching()
bool enabled
 Flag to indicate if render pass is enabled or not.
◆ OgreRenderPass()
OgreRenderPass ( )
◆ ~OgreRenderPass()
virtual ~OgreRenderPass ( )
◆ CreateRenderPass()
virtual void CreateRenderPass ( )
Reimplemented in OgreDistortionPass, OgreGaussianNoisePass, and OgreLensFlarePass.
void Destroy ( )
◆ SetCamera()
virtual void SetCamera ( Ogre::Camera *  _camera)
[in]_cameraPointer to the ogre camera.
◆ SetCameras()
virtual void SetCameras ( Ogre::Camera *  _cameras[kMaxOgreRenderPassCameras])
[in]_camerasPointer to the ogre cameras.
◆ ogreCamera
Ogre::Camera* ogreCamera[kMaxOgreRenderPassCameras] = {}
