OgreGaussianNoisePass Class Reference
Ogre implementation of the GaussianNoisePass class. More...
#include <OgreGaussianNoisePass.hh>
 OgreGaussianNoisePass ()
virtual ~OgreGaussianNoisePass ()
 Create the render pass using ogre compositor.
void Destroy () override
void PreRender () override
- Public Member Functions inherited from BaseGaussianNoisePass< OgreRenderPass >
 ~BaseGaussianNoisePass () override
double Bias () const override
 Accessor for bias.
double Mean () const override
 Accessor for mean.
void SetBiasMean (double _biasMean) override
 Set the mean of the bias value. Bias is computed based on the bias mean and bias standard deviation.
void SetBiasStdDev (double _biasStdDev) override
 Set the standard deviation of the bias value. Bias is computed based on the bias mean and bias standard deviation.
void SetMean (double _mean) override
 Set mean.
void SetStdDev (double _stdDev) override
 Set stddev.
double StdDev () const override
 Accessor for stddev.
- Public Member Functions inherited from GaussianNoisePass
virtual ~GaussianNoisePass ()
virtual ~RenderPass ()
- Public Member Functions inherited from OgreRenderPass
virtual ~OgreRenderPass ()
 Set the ogre camera that the render pass applies to.
virtual void SetCameras (Ogre::Camera *_cameras[kMaxOgreRenderPassCameras])
 Set all ogre cameras that the render pass applies to at once.
virtual ~BaseRenderPass ()
Public Attributes
std::shared_ptr< GaussianNoiseCompositorListener > gaussianNoiseCompositorListener
 Gaussian noise compositor listener.
Ogre::CompositorInstance * gaussianNoiseInstance [kMaxOgreRenderPassCameras] = {}
 Gaussian noise compositor.
- Protected Member Functions inherited from BaseGaussianNoisePass< OgreRenderPass >
void SampleBias ()
- Protected Member Functions inherited from OgreRenderPass
 OgreRenderPass ()
 BaseRenderPass ()
virtual void Init ()
- Protected Attributes inherited from BaseGaussianNoisePass< OgreRenderPass >
double bias
 Gaussian noise bias.
double biasMean
 The mean of the Gaussian distribution from which bias values are drawn.
double biasStdDev
 The standard deviation of the Gaussian distribution from which bias values are drawn.
double mean
 Gaussian noise mean.
double stdDev
 Standard deviation of Gaussian noise.
- Protected Attributes inherited from OgreRenderPass
Ogre::Camera * ogreCamera [kMaxOgreRenderPassCameras] = {}
 Pointer to the ogre camera May have more than one. Must check for nullptr on all of them. Not all RenderPasses support multiple cameras.
bool afterStitching
 Flag tracking the current value of SetWideAngleCameraAfterStitching()
bool enabled
 Flag to indicate if render pass is enabled or not.
◆ OgreGaussianNoisePass()
◆ ~OgreGaussianNoisePass()
virtual ~OgreGaussianNoisePass ( )
◆ CreateRenderPass()
void CreateRenderPass ( )
void Destroy ( )
void PreRender ( )
◆ gaussianNoiseCompositorListener
std::shared_ptr<GaussianNoiseCompositorListener> gaussianNoiseCompositorListener
◆ gaussianNoiseInstance
Ogre::CompositorInstance* gaussianNoiseInstance[kMaxOgreRenderPassCameras] = {}
