#include <BaseRayQuery.hh>
virtual RayQueryResult ClosestPoint () override
 Get ray direction. More...
 Get ray origin. More...
 Set ray direction. More...
virtual void SetFromCamera (const CameraPtr &_camera, const math::Vector2d &_coord) override
 Set ray origin. More...
virtual ~RayQuery ()
 BaseRayQuery ()
math::Vector3d direction
 Ray direction. More...
 Ray origin. More...
template<class T>
class ignition::rendering::BaseRayQuery< T >
ignition/rendering/base/BaseRayQuery.hh
◆ BaseRayQuery()
BaseRayQuery
◆ ~BaseRayQuery()
~BaseRayQuery
◆ ClosestPoint()
RayQueryResult ClosestPoint ( )
Implements RayQuery.
Reimplemented in OgreRayQuery, and Ogre2RayQuery.
◆ Direction()
gz::math::Vector3d Direction ( ) const
Get ray direction.
Ray direction.
◆ Origin()
gz::math::Vector3d Origin ( ) const
Get ray origin.
Ray origin
◆ SetDirection()
Set ray direction.
[in]_dirRay origin
◆ SetFromCamera()
void SetFromCamera ( const CameraPtr &  _camera,
◆ SetOrigin()
void SetOrigin ( const math::Vector3d &  _origin)
Set ray origin.
[in]_originRay origin
◆ direction
Ray direction.
◆ origin
Ray origin.
