Ogre2SubMesh Class Reference
Ogre2.x implementation of the submesh class. More...
#include <Ogre2Mesh.hh>
virtual | ~Ogre2SubMesh () |
Destructor. More... | |
virtual Ogre::SubItem * | Ogre2SubItem () const |
Get internal ogre subitem created from this submesh. More... | |
Public Member Functions inherited from BaseSubMesh< Ogre2Object > | |
virtual | ~BaseSubMesh () |
virtual void | Destroy () override |
virtual MaterialPtr | Material () const override |
Get the currently assigned material. More... | |
virtual void | PreRender () override |
virtual void | SetMaterial (const std::string &_name, bool _unique=true) override |
Set the materials of this SubMesh. The specified material will be retrieved from the parent Scene. If no material is registered by the given name, no work will be done. More... | |
virtual void | SetMaterial (MaterialPtr _material, bool _unique=true) override |
Set the materials of this SubMesh. More... | |
Public Member Functions inherited from SubMesh | |
virtual | ~SubMesh () |
Deconstructor. More... | |
virtual MaterialPtr | Material () const =0 |
virtual | ~Object () |
virtual | ~Ogre2Object () |
virtual ScenePtr | Scene () const override |
virtual | ~BaseObject () |
virtual unsigned int | Id () const override |
virtual std::string | Name () const override |
virtual void | PostRender () override |
Ogre2SubMesh () | |
Constructor. More... | |
virtual void | Init () |
Initialize the submesh. More... | |
virtual void | SetMaterialImpl (MaterialPtr _material) |
Helper function for setting the material to use. More... | |
Protected Member Functions inherited from BaseSubMesh< Ogre2Object > | |
BaseSubMesh () | |
Ogre2Object () | |
BaseObject () | |
virtual void | Load () |
Protected Attributes | |
Ogre::SubItem * | ogreSubItem = nullptr |
Ogre subitem representing the submesh. More... | |
Protected Attributes inherited from BaseSubMesh< Ogre2Object > | |
MaterialPtr | material |
Pointer to currently assigned material. More... | |
bool | ownsMaterial |
Flag to indicate whether or not this submesh should be responsible for destroying the material. More... | |
Ogre2ScenePtr | scene |
Pointer to the ogre scene. More... | |
unsigned int | id |
std::string | name |
◆ Ogre2SubMesh()
protected |
◆ ~Ogre2SubMesh()
virtual |
◆ Init()
protectedvirtual |
◆ Ogre2SubItem()
virtual |
◆ SetMaterialImpl()
protectedvirtual |
[in] _material Material to be assigned to the submesh
Implements BaseSubMesh< Ogre2Object >.
◆ ogreSubItem
protected |
