| | ~BaseBoundingBoxCamera () override |
| | Destructor. More...
| const std::vector< BoundingBox > & | BoundingBoxData () const override |
| | Get the BoundingBox data. More...
| gz::common::ConnectionPtr | ConnectNewBoundingBoxes (std::function< void(const std::vector< BoundingBox > &)> _subscriber) override=0 |
| | Connect to the new BoundingBox info. More...
| void | DrawBoundingBox (unsigned char *_data, const math::Color &_color, const BoundingBox &_box) const override=0 |
| | Draw a bounding box on the given image. More...
| void | SetBoundingBoxType (BoundingBoxType _type) override |
| | Set BoundingBox Type (Visible / Full) More...
| BoundingBoxType | Type () const override |
| | Get the BoundingBox Type (Visible / Full) More...
| virtual | ~BoundingBoxCamera () |
| | Destructor. More...
| virtual | ~Camera () |
| | Destructor. More...
| virtual | ~Sensor () |
| | Sensor. More...
| virtual | ~Node () |
| | Destructor. More...
| | Destructor. More...
| virtual | ~BaseCamera () |
| | Performs any necessary final rendering work. Once rendering is complete the camera will alert any listeners of the new frame event. This function should only be called after a call to Render has successfully been executed. More...
| | Right now this is Vulkan-only. This function needs to be called after rendering, and before handling the texture pointer (i.e. by calling RenderTextureMetalId()) so that external APIs (e.g. Qt) can sample the texture. More...
| | Remove all render passes from the camera. More...
