| virtual | ~Ogre2BoundingBoxCamera () |
| | Destructor. More...
| virtual const std::vector< BoundingBox > & | BoundingBoxData () const override |
| | Get the BoundingBox data. More...
| void | BoundingBoxes3D () |
| | Compute the 3D bounding boxes. More...
| virtual common::ConnectionPtr | ConnectNewBoundingBoxes (std::function< void(const std::vector< BoundingBox > &)>) override |
| | Connect to the new BoundingBox info. More...
| void | ConvertToScreenCoord (Ogre::Vector3 &_minVertex, Ogre::Vector3 &_maxVertex) const |
| | Convert from clip coord (after projection) to screen coord. More...
| void | CreateBoundingBoxTexture () |
| | Create texture to hold ogre Ids to calculate the boundaries of each ogre id mask. More...
| void | CreateRenderTexture () |
| | Create dummy render texture. Needed to satisfy inheritance and to set image's dims. More...
| | Destroy the camera. More...
| virtual void | DrawBoundingBox (unsigned char *_data, const math::Color &_color, const BoundingBox &_box) const override |
| | Draw a bounding box on the given image. More...
| void | DrawLine (unsigned char *_data, const math::Vector2i &_point1, const math::Vector2i &_point2, const math::Color &_color) const |
| | Draw line between any 2 points in the image data buffer Algorithm: https://en.wikipedia.org/wiki/Bresenham%27s_line_algorithm. More...
| void | FullBoundingBoxes () |
| | Compute the full bounding boxes by projecting all mesh vertices of each object, then get the min & max of x & y to get the full bbox. Check the visibility by looping over pixels of the ogre Ids map. More...
| | Initialize the camera. More...
| void | MarkVisibleBoxes () |
| | Mark the visible boxes by checking the ogre ids map and mark the ogre id which appears in the map. More...
| void | MeshMinimalBox (const Ogre::MeshPtr _mesh, const Ogre::Matrix4 &_viewMatrix, const Ogre::Matrix4 &_projMatrix, Ogre::Vector3 &_minVertex, Ogre::Vector3 &_maxVertex, const Ogre::Vector3 &_position, const Ogre::Quaternion &_orientation, const Ogre::Vector3 &_scale) |
| | Get minimal bounding box of the mesh by projecting the 3d vertices of the vertex buffer to 2d, then get the min & max of x & y. More...
| | Performs any necessary final rendering work. Once rendering is complete the camera will alert any listeners of the new frame event. This function should only be called after a call to Render has successfully been executed. More...
| virtual void | SetBoundingBoxType (BoundingBoxType _type) override |
| | Set BoundingBox Type (Visible / Full) More...
| virtual BoundingBoxType | Type () const override |
| | Get the BoundingBox Type (Visible / Full) More...
| void | VisibleBoundingBoxes () |
| | Compute the visible bounding boxes by looping over pixels of the ogre Ids map, to get the boundaries of each unique ogre Id mask. More...
| | ~BaseBoundingBoxCamera () override |
| | Destructor. More...
| virtual | ~BoundingBoxCamera () |
| | Destructor. More...
| virtual | ~Camera () |
| | Destructor. More...
| virtual | ~Sensor () |
| | Sensor. More...
| virtual | ~Node () |
| | Destructor. More...
| | Destructor. More...
| virtual | ~BaseCamera () |
| | Right now this is Vulkan-only. This function needs to be called after rendering, and before handling the texture pointer (i.e. by calling RenderTextureMetalId()) so that external APIs (e.g. Qt) can sample the texture. More...
| | Remove all render passes from the camera. More...
| virtual | ~Ogre2Sensor () |
| | Destructor. More...
| virtual | ~BaseSensor () |
| virtual | ~Ogre2Node () |
| | Destructor. More...
| | Get a pointer to the underlying scene node. More...
| virtual | ~BaseNode () |
| virtual | ~Ogre2Object () |
| | Destructor. More...
| virtual | ~BaseObject () |
