Poseable BoundingBox camera used for rendering bounding boxes of objects in the scene. More...
#include <BoundingBoxCamera.hh>
| virtual | ~BoundingBoxCamera () |
| Destructor. More... | |
| virtual const std::vector< BoundingBox > & | BoundingBoxData () const =0 |
| Get the BoundingBox data. More... | |
| virtual gz::common::ConnectionPtr | ConnectNewBoundingBoxes (std::function< void(const std::vector< BoundingBox > &)> _subscriber)=0 |
| Connect to the new BoundingBox info. More... | |
| virtual void | DrawBoundingBox (unsigned char *_data, const math::Color &_color, const BoundingBox &_box) const =0 |
| Draw a bounding box on the given image. More... | |
| virtual void | SetBoundingBoxType (BoundingBoxType _type)=0 |
| Set BoundingBox Type (Visible / Full) More... | |
| virtual BoundingBoxType | Type () const =0 |
| Get the BoundingBox Type (Visible / Full) More... | |
| virtual | ~Camera () |
| Renders a new frame and writes the results to the given image. This is a convenience function for single-camera scenes. It wraps the pre-render, render, post-render, and get-image calls into a single function. This should NOT be used in applications with multiple cameras or multiple consumers of a single camera's images. More... | |
| Writes the last rendered image into a caller owned buffer, for example a message payload, without an intermediate copy. Like Copy, this can be called any number of times after PostRender. The buffer must match the camera's image size and be at least _buffer.MemorySize() bytes. Nothing keeps a pointer to the buffer once this call returns. More... | |
| Performs any necessary final rendering work. Once rendering is complete the camera will alert any listeners of the new frame event. This function should only be called after a call to Render has successfully been executed. More... | |
| virtual void | PrepareForExternalSampling ()=0 |
| Right now this is Vulkan-only. This function needs to be called after rendering, and before handling the texture pointer (i.e. by calling RenderTextureMetalId()) so that external APIs (e.g. Qt) can sample the texture. More... | |
| virtual void | RemoveAllRenderPasses ()=0 |
| Remove all render passes from the camera. More... | |
| virtual void | RenderTextureMetalId (void *_textureIdPtr) const =0 |
| Get the Metal texture id associated with the render texture used by this camera. A valid Id is obtained only if the underlying render engine is Metal based. The pointer set by this function must be released to an id<MTLTexture> using CFBridgingRelease. More... | |
| virtual void | SetImageFormat (PixelFormat _format, bool _reinterpretable=false)=0 |
| Renders a new frame. This is a convenience function for single-camera scenes. It wraps the pre-render, render, and post-render into a single function. This should NOT be used in applications with multiple cameras or multiple consumers of a single camera's images. More... | |
| virtual | ~Sensor () |
| Sensor. More... | |
| virtual | ~Node () |
◆ ~BoundingBoxCamera()
virtual |
◆ BoundingBoxData()
pure virtual |
- Returns
- Buffer of bounding boxes info (label, minX, minY, maxX, maxY). If the camera's bounding box type is 3D, minZ and maxZ are also defined)
Implemented in Ogre2BoundingBoxCamera, BaseBoundingBoxCamera< T >, and BaseBoundingBoxCamera< Ogre2Sensor >.
◆ ConnectNewBoundingBoxes()
pure virtual |
[in] _subscriber Subscriber callback function
- Returns
◆ DrawBoundingBox()
pure virtual |
[in] _data buffer containing the image data [in] _color Color of the bounding box to be drawn [in] _box bounding box to be drawn
Implemented in BaseBoundingBoxCamera< T >, BaseBoundingBoxCamera< Ogre2Sensor >, and Ogre2BoundingBoxCamera.
◆ SetBoundingBoxType()
pure virtual |
[in] _type BoundingBox Type (Visible / Full)
◆ Type()
pure virtual |
- Returns
- BoundingBox Type (Visible / Full)
