BaseLensFlarePass< T > Class Template Reference
Base Gaussian noise render pass. More...
#include <BaseLensFlarePass.hh>
virtual ~BaseLensFlarePass () override
void SetLight (LightPtr _light) override
 Set the light that generates lens flare. More...
- Public Member Functions inherited from LensFlarePass
 LensFlarePass ()
virtual ~LensFlarePass ()
virtual const math::Vector3d & Color () const =0
 Returns the color set in SetColor() More...
virtual void Init (ScenePtr _scene)=0
 Initializes the Lens Flare Pass with given scene. More...
virtual uint32_t OcclusionSteps () const =0
 Returns the number of steps set in SetOcclusionSteps() More...
virtual double Scale () const =0
 Returns the scale set in SetScale() More...
virtual void SetColor (const math::Vector3d &_color)=0
 Set the color of lens flare. More...
virtual void SetOcclusionSteps (uint32_t _occlusionSteps)=0
 Set the number of steps to take in each direction when checking for occlusions. More...
virtual void SetScale (double _scale)=0
 Set the scale of lens flare. More...
virtual ~RenderPass ()
virtual void SetWideAngleCameraAfterStitching (bool _afterStitching)=0
virtual bool WideAngleCameraAfterStitching () const =0
LightPtr light
 Light that generates the lens flare. More...
template<class T>
class gz::rendering::BaseLensFlarePass< T >
◆ BaseLensFlarePass()
BaseLensFlarePass
◆ ~BaseLensFlarePass()
~BaseLensFlarePass
◆ SetLight()
void SetLight ( LightPtr  _light)
[in]_lightPointer to light
Implements LensFlarePass.
◆ light
LightPtr light
