LensFlarePass Class Referenceabstract
A render pass that applies Lens Flare to the render target. More...
#include <LensFlarePass.hh>
 LensFlarePass ()
virtual ~LensFlarePass ()
virtual const math::Vector3d & Color () const =0
 Returns the color set in SetColor() More...
virtual void Init (ScenePtr _scene)=0
 Initializes the Lens Flare Pass with given scene. More...
virtual uint32_t OcclusionSteps () const =0
 Returns the number of steps set in SetOcclusionSteps() More...
virtual double Scale () const =0
 Returns the scale set in SetScale() More...
virtual void SetColor (const math::Vector3d &_color)=0
 Set the color of lens flare. More...
virtual void SetLight (LightPtr _light)=0
 Set the light that generates lens flare. More...
virtual void SetOcclusionSteps (uint32_t _occlusionSteps)=0
 Set the number of steps to take in each direction when checking for occlusions. More...
virtual void SetScale (double _scale)=0
 Set the scale of lens flare. More...
virtual ~RenderPass ()
virtual void SetWideAngleCameraAfterStitching (bool _afterStitching)=0
virtual bool WideAngleCameraAfterStitching () const =0
◆ LensFlarePass()
◆ ~LensFlarePass()
virtual ~LensFlarePass ( )
◆ Color()
virtual const math::Vector3d& Color ( ) const
Color of lens flare
Implemented in Ogre2LensFlarePass, and OgreLensFlarePass.
virtual void Init ( ScenePtr  _scene)
[in]_scenePointer to scene
◆ OcclusionSteps()
virtual uint32_t OcclusionSteps ( ) const
Number of occlusion steps
◆ Scale()
virtual double Scale ( ) const
Scale of lens flare
◆ SetColor()
virtual void SetColor ( const math::Vector3d &  _color)
[in]_colorColor of lens flare
◆ SetLight()
virtual void SetLight ( LightPtr  _light)
[in]_lightPointer to light
Implemented in BaseLensFlarePass< T >, BaseLensFlarePass< OgreRenderPass >, and BaseLensFlarePass< Ogre2RenderPass >.
◆ SetOcclusionSteps()
virtual void SetOcclusionSteps ( uint32_t  _occlusionSteps)
[in]_occlusionStepsnumber of steps to take in each direction when checking for occlusion. A value of 0 disables occlusion.
◆ SetScale()
virtual void SetScale ( double  _scale)
[in]_scaleScale of lens flare
