OgreLensFlarePass Class Reference
Ogre Implementation of a Lens Flare render pass. More...
#include <OgreLensFlarePass.hh>
 OgreLensFlarePass ()
 ~OgreLensFlarePass () override
const math::Vector3d & Color () const override
 Returns the color set in SetColor() More...
void Destroy () override
void Init (ScenePtr _scene) override
 Initializes the Lens Flare Pass with given scene. More...
uint32_t OcclusionSteps () const override
 Returns the number of steps set in SetOcclusionSteps() More...
void PostRender () override
double Scale () const override
 Returns the scale set in SetScale() More...
void SetColor (const math::Vector3d &_color) override
 Set the color of lens flare. More...
void SetOcclusionSteps (uint32_t _occlusionSteps) override
 Set the number of steps to take in each direction when checking for occlusions. More...
void SetScale (double _scale) override
 Set the scale of lens flare. More...
- Public Member Functions inherited from BaseLensFlarePass< OgreRenderPass >
virtual ~BaseLensFlarePass () override
void SetLight (LightPtr _light) override
 Set the light that generates lens flare. More...
- Public Member Functions inherited from LensFlarePass
 LensFlarePass ()
virtual ~LensFlarePass ()
virtual ~RenderPass ()
- Public Member Functions inherited from OgreRenderPass
virtual ~OgreRenderPass ()
 Set the ogre camera that the render pass applies to. More...
virtual void SetCameras (Ogre::Camera *_cameras[kMaxOgreRenderPassCameras])
 Set all ogre cameras that the render pass applies to at once. More...
virtual ~BaseRenderPass ()
- Protected Member Functions inherited from BaseLensFlarePass< OgreRenderPass >
- Protected Member Functions inherited from OgreRenderPass
 OgreRenderPass ()
 BaseRenderPass ()
virtual void Init ()
- Protected Attributes inherited from BaseLensFlarePass< OgreRenderPass >
LightPtr light
 Light that generates the lens flare. More...
- Protected Attributes inherited from OgreRenderPass
Ogre::Camera * ogreCamera [kMaxOgreRenderPassCameras] = {}
 Pointer to the ogre camera May have more than one. Must check for nullptr on all of them. Not all RenderPasses support multiple cameras. More...
bool afterStitching
 Flag tracking the current value of SetWideAngleCameraAfterStitching() More...
bool enabled
◆ OgreLensFlarePass()
◆ ~OgreLensFlarePass()
~OgreLensFlarePass ( )
◆ Color()
const math::Vector3d& Color ( ) const
Color of lens flare
Implements LensFlarePass.
◆ CreateRenderPass()
void CreateRenderPass ( )
void Destroy ( )
void Init ( ScenePtr  _scene)
[in]_scenePointer to scene
◆ OcclusionSteps()
uint32_t OcclusionSteps ( ) const
Number of occlusion steps
◆ PostRender()
void PostRender ( )
void PreRender ( const CameraPtr &  _camera)
Implements RenderPass.
◆ Scale()
double Scale ( ) const
Scale of lens flare
◆ SetColor()
void SetColor ( const math::Vector3d &  _color)
[in]_colorColor of lens flare
◆ SetOcclusionSteps()
void SetOcclusionSteps ( uint32_t  _occlusionSteps)
[in]_occlusionStepsnumber of steps to take in each direction when checking for occlusion. A value of 0 disables occlusion.
◆ SetScale()
void SetScale ( double  _scale)
[in]_scaleScale of lens flare
