Ogre implementation of the RenderPass class. More...
#include <OgreRenderPass.hh>
virtual ~OgreRenderPass ()
virtual void CreateRenderPass ()
void Destroy () override
 Set the ogre camera that the render pass applies to. More...
virtual void SetCameras (Ogre::Camera *_cameras[kMaxOgreRenderPassCameras])
 Set all ogre cameras that the render pass applies to at once. More...
virtual ~BaseRenderPass ()
virtual ~RenderPass ()
 OgreRenderPass ()
 BaseRenderPass ()
virtual void Init ()
Ogre::Camera * ogreCamera [kMaxOgreRenderPassCameras] = {}
 Pointer to the ogre camera May have more than one. Must check for nullptr on all of them. Not all RenderPasses support multiple cameras. More...
bool afterStitching
 Flag tracking the current value of SetWideAngleCameraAfterStitching() More...
bool enabled
◆ OgreRenderPass()
OgreRenderPass ( )
◆ ~OgreRenderPass()
virtual ~OgreRenderPass ( )
◆ CreateRenderPass()
virtual void CreateRenderPass ( )
Reimplemented in OgreLensFlarePass, OgreGaussianNoisePass, and OgreDistortionPass.
void Destroy ( )
◆ SetCamera()
virtual void SetCamera ( Ogre::Camera *  _camera)
[in]_cameraPointer to the ogre camera.
◆ SetCameras()
virtual void SetCameras ( Ogre::Camera *  _cameras[kMaxOgreRenderPassCameras])
[in]_camerasPointer to the ogre cameras.
◆ ogreCamera
Ogre::Camera* ogreCamera[kMaxOgreRenderPassCameras] = {}
