#include <Ogre2RenderPass.hh>
virtual ~Ogre2RenderPass ()
virtual void CreateRenderPass ()
void Destroy () override
std::string OgreCompositorNodeDefinitionName () const
 Get the ogre compositor node definition name for this render pass. More...
virtual void WorkspaceAdded (Ogre::CompositorWorkspace *_workspace)
 Notifies Ogre2RenderPass that a new workspace has been created. More...
virtual void WorkspaceRemoved (Ogre::CompositorWorkspace *_workspace)
 Notifies Ogre2RenderPass that a workspace will be destroyed. More...
- Public Member Functions inherited from BaseRenderPass< Ogre2Object >
virtual ~BaseRenderPass ()
virtual ~RenderPass ()
 Ogre2RenderPass ()
- Protected Member Functions inherited from BaseRenderPass< Ogre2Object >
 BaseRenderPass ()
virtual void Init ()
std::string ogreCompositorNodeDefName
 Name of the ogre compositor node definition. More...
- Protected Attributes inherited from BaseRenderPass< Ogre2Object >
bool afterStitching
 Flag tracking the current value of SetWideAngleCameraAfterStitching() More...
bool enabled
The ogre2 compositor chain in gz-rendering is set up as follows:
  • Base scene pass -> [0..N] RenderPass'es -> Final compositor pass. This is set up by Ogre2RenderTarget which loads the compositor workspace definition from script. The base scene pass node is responsible for rendering the initial scene and passes its output to any RenderPass'es that are added to the RenderTarget. Each RenderPass has its own ogre compositor node that receives the output from the previous RenderPass as input, applies its own pass over the input, and sends the result to the next RenderPass. Note that the Ogre2RenderPass class provides the node definition only and the actual node creation work is done in the Ogre2RenderTarget class when the whole workspace is constructed.
◆ Ogre2RenderPass()
Ogre2RenderPass ( )
◆ ~Ogre2RenderPass()
virtual ~Ogre2RenderPass ( )
◆ CreateRenderPass()
virtual void CreateRenderPass ( )
Reimplemented in Ogre2GaussianNoisePass.
void Destroy ( )
◆ OgreCompositorNodeDefinitionName()
std::string OgreCompositorNodeDefinitionName ( ) const
◆ WorkspaceAdded()
virtual void WorkspaceAdded ( Ogre::CompositorWorkspace *  _workspace)
[in]_workspaceworkspace that was created
Reimplemented in Ogre2LensFlarePass.
◆ WorkspaceRemoved()
virtual void WorkspaceRemoved ( Ogre::CompositorWorkspace *  _workspace)
[in]_workspaceworkspace about to be destroyed
◆ ogreCompositorNodeDefName
