#include <OgreLight.hh>
virtual ~OgrePointLight ()
- Public Member Functions inherited from BasePointLight< OgreLight >
virtual ~BasePointLight ()
- Public Member Functions inherited from PointLight
virtual ~PointLight ()
virtual ~Light ()
 ~OgreLight () override
void SetAttenuationConstant (double _value) override
void SetAttenuationLinear (double _value) override
void SetAttenuationQuadratic (double _value) override
void SetAttenuationRange (double _range) override
void SetCastShadows (bool _castShadows) override
void SetDiffuseColor (const math::Color &_color) override
void SetSpecularColor (const math::Color &_color) override
 ~BaseLight () override
void SetDiffuseColor (double _r, double _g, double _b, double _a=1.0) override
void SetSpecularColor (double _r, double _g, double _b, double _a=1.0) override
virtual ~OgreNode ()
 OgrePointLight ()
- Protected Member Functions inherited from BasePointLight< OgreLight >
 BasePointLight ()
 OgreLight ()
 BaseLight ()
 OgreNode ()
double attenConstant
double attenLinear
double attenQuadratic
double attenRange
Ogre::Light * ogreLight
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgrePointLight()
OgrePointLight ( )
◆ ~OgrePointLight()
virtual ~OgrePointLight ( )
