Ogre2.x implementation of the inertia visual class. More...
#include <Ogre2InertiaVisual.hh>
virtual ~Ogre2InertiaVisual ()
VisualPtr BoxVisual () const override
 Get the box visual.
 Initialize the visual.
void Load (const gz::math::Pose3d &_pose, const gz::math::Vector3d &_scale) override
 Load the Inertia visual from its pose and scale.
 Set the material for all attached visuals and geometries.
- Public Member Functions inherited from BaseInertiaVisual< Ogre2Visual >
virtual ~BaseInertiaVisual ()
 Set the inertial component of the visual.
virtual ~InertiaVisual ()
virtual ~Ogre2Visual ()
 Set visibility flags.
 Enable or disable wireframe.
virtual ~BaseVisual ()
 Add visibility flags.
 Get the local pose.
 Remove visibility flags.
 Set the local pose.
 Get visibility flags.
virtual ~Ogre2Node ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 Set material to line geometry.
- Protected Member Functions inherited from BaseInertiaVisual< Ogre2Visual >
 Ogre2Visual ()
 BaseVisual ()
 Ogre2Node ()
 Set the parent node.
 Pointer to the attached geometries.
uint32_t visibilityFlags
 Visual's visibility flags.
bool wireframe
Ogre2NodeStorePtr children
 A list of child nodes.
Ogre2NodePtr parent
 Pointer to the ogre scene.
◆ Ogre2InertiaVisual()
Ogre2InertiaVisual ( )
◆ ~Ogre2InertiaVisual()
virtual ~Ogre2InertiaVisual ( )
◆ BoxVisual()
VisualPtr BoxVisual ( ) const
Get the box visual.
Pointer to the box visual
Reimplemented from BaseInertiaVisual< Ogre2Visual >.
◆ Load()
void Load ( const gz::math::Pose3d &  _pose,
const gz::math::Vector3d &  _scale
Implements Visual.
◆ SetMaterial()
bool  _unique
Implements Visual.
◆ SetMaterialImpl()
[in]_materialOgre material.
