RenderingSensor Class Reference
#include <RenderingSensor.hh>
| virtual | ~RenderingSensor () |
| destructor More... | |
| bool | ManualSceneUpdate () const |
| Get whether the scene graph is updated manually. Defaults to false. More... | |
| void | Render () |
| Render update. This performs the actual render operation. More... | |
| rendering::ScenePtr | Scene () const |
| Get the rendering scene. More... | |
| void | SetManualSceneUpdate (bool _manual) |
| Set whether to update the scene graph manually. If set to true, it is expected that rendering::Scene::PreRender is called manually before calling Render() More... | |
| virtual void | SetScene (rendering::ScenePtr _scene) |
| Set the rendering scene. More... | |
| virtual | ~Sensor () |
| Add a sequence number to an gz::msgs::Header. This function can be called by a sensor that wants to add a sequence number to a sensor message in order to have improved accountability for generated sensor data. More... | |
| FrameId. More... | |
| SensorId | Id () const |
| virtual bool | Init () |
| virtual bool | Load (const sdf::Sensor &_sdf) |
| virtual bool | Load (sdf::ElementPtr _sdf) |
| Get name. More... | |
| common::Time | NextUpdateTime () const |
| virtual bool | Update (const common::Time &_now)=0 |
| bool | Update (const common::Time &_now, const bool _force) |
| RenderingSensor () | |
| constructor More... | |
| void | AddSensor (rendering::SensorPtr _sensor) |
| Add a rendering::Sensor. Its render updates will be handled by this base class. More... | |
| Sensor () | |
This class is a base for all rendering sensor classes. It provides interface to ignition rendering objects
◆ RenderingSensor()
protected |
constructor
◆ ~RenderingSensor()
virtual |
destructor
◆ AddSensor()
protected |
[in] _sensor Sensor to add.
◆ ManualSceneUpdate()
| bool ManualSceneUpdate | ( | ) | const |
- Returns
- True if manual scene graph update is enabled, false otherwise
- See also
- SetManualSceneUpdate
◆ Render()
| void Render | ( | ) |
◆ Scene()
| rendering::ScenePtr Scene | ( | ) | const |
◆ SetManualSceneUpdate()
| void SetManualSceneUpdate | ( | bool | _manual | ) |
[in] _manual True to enable manual scene graph update
◆ SetScene()
virtual |
[in] _scene Pointer to the scene
