Gazebo Sensors
ignition::sensors Namespace Reference
Sensors namespace. More...
class  AirPressureSensor
class  AltimeterSensor
class  CameraSensor
 Camera Sensor Class. More...
class  DepthCameraSensor
class  GaussianNoiseModel
 Gaussian noise class. More...
class  GpuLidarSensor
 GpuLidar Sensor Class. More...
class  ImageGaussianNoiseModel
 Gaussian noise class for image sensors. More...
class  ImageNoiseFactory
class  ImuSensor
 Imu Sensor Class. More...
class  Lidar
class  LogicalCameraSensor
class  MagnetometerSensor
class  Manager
class  Noise
class  NoiseFactory
class  RenderingEvents
class  RenderingSensor
class  RgbdCameraSensor
class  Sensor
 a base sensor class More...
class  SensorFactory
 A factory class for creating sensors This class wll load a sensor plugin based on the given sensor type and instantiates a sensor object. More...
class  SensorPlugin
 Base sensor plugin interface. More...
class  SensorTypePlugin
 Templated class for instantiating sensors of the specified type. More...
class  ThermalCameraSensor
typedef std::vector< CameraSensorPtr > CameraSensor_V
typedef std::shared_ptr< CameraSensor > CameraSensorPtr
typedef std::shared_ptr< GaussianNoiseModel > GaussianNoiseModelPtr
typedef std::vector< GpuLidarSensorPtr > GpuLidarSensor_V
typedef std::shared_ptr< GpuLidarSensor > GpuLidarSensorPtr
typedef std::shared_ptr< ImageGaussianNoiseModel > ImageGaussianNoiseModelPtr
 Shared pointer to Noise. More...
typedef std::shared_ptr< Noise > NoisePtr
typedef std::vector< SensorPtr > Sensor_V
using SensorId = std::size_t
 A string used to identify a sensor. More...
typedef std::shared_ptr< Sensor > SensorPtr
Enumerations
enum  NoiseType : int { NONE = 0, CUSTOM = 1, GAUSSIAN = 2 }
 Which noise types we support. More...
enum  SensorCategory { IMAGE = 0, RAY = 1, OTHER = 2, CATEGORY_COUNT = 3 }
 SensorCategory is used to categorize sensors. This is used to put sensors into different threads. More...
enum  SensorNoiseType {
  SENSOR_NOISE_TYPE_BEGIN = 0, NO_NOISE = SENSOR_NOISE_TYPE_BEGIN, CAMERA_NOISE = 1, MAGNETOMETER_X_NOISE_TESLA = 2,
  MAGNETOMETER_Y_NOISE_TESLA = 3, MAGNETOMETER_Z_NOISE_TESLA = 4, ALTIMETER_VERTICAL_POSITION_NOISE_METERS = 5, ALTIMETER_VERTICAL_VELOCITY_NOISE_METERS_PER_S = 6,
  AIR_PRESSURE_NOISE_PASCALS = 7, ACCELEROMETER_X_NOISE_M_S_S = 8, ACCELEROMETER_Y_NOISE_M_S_S = 9, ACCELEROMETER_Z_NOISE_M_S_S = 10,
  GYROSCOPE_X_NOISE_RAD_S = 11, GYROSCOPE_Y_NOISE_RAD_S = 12, GYROSCOPE_Z_NOISE_RAD_S = 13, LIDAR_NOISE = 14,
  SENSOR_NOISE_TYPE_END
Variables
const SensorId NO_SENSOR = 0
Sensors namespace.
Typedef Documentation
◆ CameraSensor_V
◆ CameraSensorPtr
◆ GaussianNoiseModelPtr
◆ GpuLidarSensor_V
◆ GpuLidarSensorPtr
◆ ImageGaussianNoiseModelPtr
◆ NoisePtr
◆ Sensor_V
◆ SensorId
◆ SensorPtr
◆ NoiseType
strong
Enumerator
NONE
CUSTOM
GAUSSIAN
◆ SensorCategory
Enumerator
Image based sensor class. This type requires the rendering engine.
RAY
Ray based sensor class.
OTHER
A type of sensor is not a RAY or IMAGE sensor.
CATEGORY_COUNT
Number of Sensor Categories.
◆ SensorNoiseType
Enumerator
NO_NOISE
Noise streams for the Camera sensor.
CameraSensor
CAMERA_NOISE
CameraSensor
Magnetometer body-frame X axis noise in Tesla.
MagnetometerSensor
Magnetometer body-frame Y axis noise in Tesla.
MagnetometerSensor
Magnetometer body-frame Z axis noise in Tesla.
MagnetometerSensor
Vertical noise stream for the altimeter sensor.
AltimeterSensor
Velocity noise streams for the altimeter sensor.
AltimeterSensor
Air Pressure noise streams for the air pressure sensor.
AirPressureSensor
Accelerometer body-frame X axis noise in m/s^2.
ImuSensor
Accelerometer body-frame Y axis noise in m/s^2.
ImuSensor
Accelerometer body-frame Z axis noise in m/s^2.
ImuSensor
Gyroscope body-frame X axis noise in m/s^2.
ImuSensor
ImuSensor
ImuSensor
LIDAR_NOISE
Noise streams for the Lidar sensor.
Lidar
Variable Documentation
◆ NO_SENSOR
