Gazebo Sensors
Manager Class Reference
#include <Manager.hh>
 Manager ()
 constructor More...
virtual ~Manager ()
 destructor More...
void AddPluginPaths (const std::string &_path)
 Adds colon delimited paths sensor plugins may be. More...
SensorId CreateSensor (const sdf::Sensor &_sdf)
 Create a sensor from SDF without a known sensor type. More...
template<typename T >
T * CreateSensor (sdf::ElementPtr _sdf)
 Create a sensor from SDF with a known sensor type. More...
SensorId CreateSensor (sdf::ElementPtr _sdf)
T * CreateSensor (sdf::Sensor _sdf)
bool Init ()
 Initialize the sensor library without rendering or physics. More...
bool Remove (const SensorId _id)
 Remove a sensor by ID. More...
void RunOnce (const gz::common::Time &_time, bool _force=false)
 Run the sensor generation one step. More...
Sensor * Sensor (SensorId _id)
 Get an instance of a loaded sensor by sensor id. More...
This class is responsible for loading and running sensors, and providing sensors with common environments to generat data from.
The primary interface through which to load a sensor is LoadSensor(). This takes an sdf element pointer that should be configured with everything the sensor will need. Custom sensors configuration must be in the <plugin> tag of the sdf::Element. The manager will dynamically load the sensor library and update it.
Remarks
This class is not thread safe.
◆ Manager()
Manager ( )
constructor
◆ ~Manager()
virtual ~Manager ( )
destructor
◆ AddPluginPaths()
void AddPluginPaths ( const std::string &  _path)
◆ CreateSensor() [1/4]
SensorId CreateSensor ( const sdf::Sensor &  _sdf)
This creates sensors by looking at the given sdf element. Sensors created with this API offer an ignition-transport interface. If you need a direct C++ interface to the data, you must get the sensor pointer and cast to the correct type.
A <sensor> tag may have multiple <plugin> tags. A SensorId will be returned for each plugin that is described in SDF. If there are no <plugin> tags then one of the plugins shipped with this library will be loaded. For example, a <sensor> tag with <camera> but no <plugin> will load a CameraSensor from ignition-sensors-camera.
Sensor()
[in]_sdfSDF sensor DOM object
A sensor id that refers to the created sensor. NO_SENSOR is returned on erro.
◆ CreateSensor() [2/4]
T* CreateSensor ( sdf::ElementPtr  _sdf)
inline
Sensor()
[in]_sdfpointer to the sdf element
A pointer to the created sensor. nullptr returned on error.
References Manager::CreateSensor(), std::endl(), ignition::sensors::NO_SENSOR, and Manager::Sensor().
◆ CreateSensor() [3/4]
SensorId CreateSensor ( sdf::ElementPtr  _sdf)
Sensor()
◆ CreateSensor() [4/4]
T* CreateSensor ( sdf::Sensor  _sdf)
inline
Sensor()
References ignition::sensors::NO_SENSOR, and Manager::Sensor().
bool Init ( )
True if successfully initialized, false if not
◆ Remove()
bool Remove ( const SensorId  _id)
[in]_sensorIdID of the sensor to remove
True if the sensor exists and removed.
◆ RunOnce()
void RunOnce ( const gz::common::Time &  _time,
bool  _force = false
_timeThe current simulated time
_forceIf true, all sensors are forced to update. Otherwise a sensor will update based on it's Hz rate.
◆ Sensor()
Sensor* Sensor ( SensorId  _id)
[in]_idIdenitifier of the sensor.
Pointer to the sensor, nullptr on error.
