Gazebo Sensors
Camera Sensor Class. More...
#include <CameraSensor.hh>
 CameraSensor ()
 constructor More...
virtual ~CameraSensor ()
 destructor More...
double Baseline () const
virtual unsigned int ImageHeight () const
 Get image height. More...
virtual unsigned int ImageWidth () const
 Get image width. More...
virtual bool Init () override
virtual bool Update (const common::Time &_now) override
virtual ~RenderingSensor ()
 destructor More...
void Render ()
 destructor More...
bool EnableMetrics () const
std::string FrameId () const
 FrameId. More...
SensorId Id () const
 Get the sensor's ID. More...
std::string Name () const
 Get name. More...
common::Time NextUpdateTime () const
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
std::string Topic () const
bool Update (const common::Time &_now, const bool _force)
 Update the sensor. More...
double UpdateRate () const
bool AdvertiseInfo ()
void PublishInfo (const gz::common::Time &_now)
 RenderingSensor ()
 constructor More...
 Sensor ()
 constructor More...
This class creates images from an ignition rendering scene. The scene must be created in advance and given to Manager::Init(). It offers both an ignition-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ CameraSensor()
constructor
◆ ~CameraSensor()
virtual ~CameraSensor ( )
destructor
◆ AdvertiseInfo() [1/2]
bool AdvertiseInfo ( )
True if successful.
◆ AdvertiseInfo() [2/2]
bool AdvertiseInfo ( const std::string &  _topic)
[in]_topicThe topic on which camera info is to be published.
True if successful.
◆ Baseline()
double Baseline ( ) const
The distance from the 1st camera, in meters.
◆ ConnectImageCallback()
gz::common::ConnectionPtr ConnectImageCallback ( std::function< void(const gz::msgs::Image &)>  _callback)
Remarks
◆ ImageHeight()
Get image height.
height of the image
Reimplemented in DepthCameraSensor, ThermalCameraSensor, and RgbdCameraSensor.
◆ ImageWidth()
Get image width.
width of the image
◆ InfoTopic()
std::string InfoTopic ( ) const
Camera info topic.
virtual bool Init ( )
True on success
Reimplemented from Sensor.
◆ Load() [1/2]
◆ Load() [2/2]
Reimplemented in DepthCameraSensor, and ThermalCameraSensor.
◆ PopulateInfo()
void PopulateInfo ( const sdf::Camera *  _cameraSdf)
[in]_cameraSdfPointer to SDF object containing camera information.
◆ PublishInfo()
void PublishInfo ( const gz::common::Time &  _now)
[in]_nowThe current time
◆ RenderingCamera()
rendering::CameraPtr RenderingCamera ( ) const
Camera in Gazebo Rendering.
◆ SetBaseline()
void SetBaseline ( double  _baseline)
[in]_baselineThe distance from the 1st camera, in meters.
◆ SetScene()
virtual bool Update ( const common::Time &  _now)
Implements Sensor.
