Gazebo Sensors
DepthCameraSensor Class Reference
#include <DepthCameraSensor.hh>
 DepthCameraSensor ()
 constructor More...
virtual ~DepthCameraSensor ()
 destructor More...
virtual rendering::DepthCameraPtr DepthCamera ()
virtual double FarClip () const
 Get image width. More...
 Get image height. More...
virtual bool Init () override
virtual double NearClip () const
void OnNewDepthFrame (const float *_scan, unsigned int _width, unsigned int _height, unsigned int, const std::string &)
 Depth data callback used to get the data from the sensor. More...
void OnNewRgbPointCloud (const float *_data, unsigned int _width, unsigned int _height, unsigned int, const std::string &)
 Point cloud data callback used to get the data from the sensor. More...
virtual bool Update (const common::Time &_now) override
 CameraSensor ()
 constructor More...
virtual ~CameraSensor ()
 destructor More...
double Baseline () const
virtual ~RenderingSensor ()
 destructor More...
void Render ()
 destructor More...
bool EnableMetrics () const
std::string FrameId () const
 FrameId. More...
SensorId Id () const
 Get the sensor's ID. More...
std::string Name () const
 Get name. More...
common::Time NextUpdateTime () const
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
std::string Topic () const
bool Update (const common::Time &_now, const bool _force)
 Update the sensor. More...
double UpdateRate () const
bool AdvertiseInfo ()
void PublishInfo (const gz::common::Time &_now)
 RenderingSensor ()
 constructor More...
 Sensor ()
 constructor More...
This class creates depth image from an ignition rendering scene. The scene must be created in advance and given to Manager::Init(). It offers both an ignition-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ DepthCameraSensor()
constructor
◆ ~DepthCameraSensor()
virtual ~DepthCameraSensor ( )
destructor
◆ ConnectImageCallback()
gz::common::ConnectionPtr ConnectImageCallback ( std::function< void(const gz::msgs::Image &)>  _callback)
Remarks
◆ DepthCamera()
virtual rendering::DepthCameraPtr DepthCamera ( )
[in]_nowThe current time
◆ FarClip()
virtual double FarClip ( ) const
Get image width.
width of the image
◆ ImageHeight()
Get image height.
height of the image
◆ ImageWidth()
Get image width.
width of the image
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ NearClip()
virtual double NearClip ( ) const
Get image height.
height of the image
◆ OnNewDepthFrame()
void OnNewDepthFrame ( const float *  _scan,
unsigned int  ,
const std::string &
[in]_scanpointer to the data from the sensor
[in]_widthwidth of the depth image
[in]_heightheight of the depth image
[in]_channelbytes used for the depth data
[in]_formatstring with the format
◆ OnNewRgbPointCloud()
void OnNewRgbPointCloud ( const float *  _data,
unsigned int  ,
const std::string &
[in]_datapointer to the data from the sensor
[in]_widthwidth of the point cloud image
[in]_heightheight of the point cloud image
[in]_channelbytes used for the point cloud data
◆ SetScene()
virtual bool Update ( const common::Time &  _now)
