Gazebo Sensors
a base sensor class More...
#include <Sensor.hh>
 destructor More...
bool EnableMetrics () const
std::string FrameId () const
 FrameId. More...
SensorId Id () const
 Get the sensor's ID. More...
virtual bool Init ()
virtual bool Load (sdf::ElementPtr _sdf)
std::string Name () const
 Get name. More...
common::Time NextUpdateTime () const
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
std::string Topic () const
virtual bool Update (const common::Time &_now)=0
bool Update (const common::Time &_now, const bool _force)
 Update the sensor. More...
double UpdateRate () const
 Sensor ()
 constructor More...
a base sensor class
This class is a base for all sensor classes. It parses some common SDF elements in the <sensor> tag and is responsible for making sure sensors update at the right time.
◆ Sensor()
Sensor ( )
constructor
◆ ~Sensor()
virtual ~Sensor ( )
destructor
◆ AddSequence()
void AddSequence ( gz::msgs::Header *  _msg,
const std::string &  _seqKey = "default"
This function will add the following key-value pair to the data field in the provided gz::msgs::Header msg.
  • key: "seq"
  • value: sequence_number
If the "seq" key already exists, then the value will be set without adding another key-value pair.
The sequence_number starts at zero, when a sensor is created, and is incremented by one each time this function is called.
[in,out]_msgThe header which will receive the sequence.
[in]_seqKeyName of the sequence to use.
◆ EnableMetrics()
bool EnableMetrics ( ) const
True if performance metrics are enabled, false otherwise.
◆ FrameId()
std::string FrameId ( ) const
FrameId.
FrameId of sensor.
◆ Id()
SensorId Id ( ) const
The sensor's ID.
◆ Load() [1/2]
[in]_sdfSDF <sensor> or <plugin> inside of <sensor>
Reimplemented in DepthCameraSensor, ThermalCameraSensor, CameraSensor, GpuLidarSensor, Lidar, RgbdCameraSensor, ImuSensor, MagnetometerSensor, AirPressureSensor, and AltimeterSensor.
◆ Load() [2/2]
Reimplemented in DepthCameraSensor, ThermalCameraSensor, CameraSensor, GpuLidarSensor, Lidar, LogicalCameraSensor, ImuSensor, MagnetometerSensor, AirPressureSensor, and AltimeterSensor.
◆ Name()
std::string Name ( ) const
Get name.
Name of sensor.
◆ NextUpdateTime()
common::Time NextUpdateTime ( ) const
◆ Parent()
std::string Parent ( ) const
Parent link of sensor.
◆ Pose()
gz::math::Pose3d Pose ( ) const
Current pose of the sensor.
◆ PublishMetrics()
void PublishMetrics ( const std::chrono::duration< double > &  _now)
[in]_nowCurrent time.
◆ SDF()
sdf::ElementPtr SDF ( ) const
Pointer to an SDF element that contains initialization information for this sensor.
◆ SetEnableMetrics()
void SetEnableMetrics ( bool  _enableMetrics)
[in]_enableMetricsTrue to enable.
◆ SetFrameId()
void SetFrameId ( const std::string &  _frameId)
[in]_frameIdFrame ID of the sensor
◆ SetParent()
virtual void SetParent ( const std::string &  _parent)
Reimplemented in Lidar.
◆ SetPose()
void SetPose ( const gz::math::Pose3d &  _pose)
◆ SetTopic()
bool SetTopic ( const std::string &  _topic)
[in]_topicTopic sensor publishes data to.
True if a valid topic was set.
◆ SetUpdateRate()
void SetUpdateRate ( const double  _hz)
[in]_hzUpdate rate of sensor in Hertz.
◆ Topic()
std::string Topic ( ) const
◆ Update() [1/2]
virtual bool Update ( const common::Time &  _now)
[in]_nowThe current time
SetUpdateRate()
Implemented in DepthCameraSensor, ThermalCameraSensor, CameraSensor, LogicalCameraSensor, RgbdCameraSensor, GpuLidarSensor, ImuSensor, MagnetometerSensor, AirPressureSensor, AltimeterSensor, and Lidar.
◆ Update() [2/2]
bool Update ( const common::Time &  _now,
const bool  _force
Update the sensor.
True if the update was triggered (_force was true or _now >= next_update_time) and the sensor's bool Sensor::Update(const common::Time &_now) function returned true. False otherwise.
Remarks
virtual bool Update(const common::Time &_name) = 0
◆ UpdateRate()
double UpdateRate ( ) const
The update rate is the number of times per second a sensor should generate and output data.
_hz update rate of sensor.
